KZ1000 BS34s not right
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ1000 BS34s not right
17 Aug 2023 13:01
#888403
Just to be abundantly clear, we are talking about reference number 16016 in this diagram.
www.partzilla.com/catalog/kawasaki/motor...-k1/carburetor-parts
On the right end, you can just see a needle-like projection. In the larger section next to it is a seal. When the seal gets old and hard, it will let fuel pass by into the carburetor throat. You will not see any external leaks. Replacing those seals is really tedious, so I second the motion to contact Zed1015, as he has been doing it for a while and seems to have the process down to a fine science.
  • OkieZ1000
  • OkieZ1000's Avatar Topic Author
17 Aug 2023 17:13
#888415
TexasKZ,
Appreciate the clarification.
I pulled the carbs and broke them down.  Like most things on this bike, a PO only installed 1 of the ball bearings that set the choke stops, not sure that has anything to do with anything,  but just annoying.
I don't know really what normal feels like for these things, the borres seem to fit well but the nut has a bit of play on the shaft.  Not sure how squishy the seals are supposed to be.  They are for sure not "rock hard", but most likely OE.
It sounds like getting the choke back to spec is a logical next step.
I'll be getting in touch with Zed1015.
Thanks for the information, it's given me a direction to go.......
  • Nessism
  • Nessism's Avatar
17 Aug 2023 18:04
#888417
It looks like someone soaked the choke plunger in some sort of strong solvent, because they are pooched, instead of being slightly recessed in the plunger.  I'd say that you may have found the problem.
The following user(s) said Thank You: OkieZ1000
  • OkieZ1000
17 Aug 2023 18:23
#888419
Nessism,
Awesome that you can spot that from the photos of such an obscure part!
If it's pooched out that far, could they have been installed backward?  (It wouldn't surprise me with everything else I have seen on these carbs)
Again,  appreciate the input from everyone.....
  • OkieZ1000
17 Aug 2023 18:25
#888420
Thanks Cra-Z1, you were the first one to start this direction......
  • Nessism
  • Nessism's Avatar
17 Aug 2023 19:03
#888421
Check how the rubber donut on your plunger bulges out, compared to how the rubber donut is supposed to look...
  • OkieZ1000
17 Aug 2023 19:29
#888423
Feeling dumb, can't find the PM function on the site......
  • TexasKZ
  • TexasKZ's Avatar
17 Aug 2023 20:09
#888427
There isn’t one.
  • daveo
  • daveo's Avatar
  • Premium Member
17 Aug 2023 22:05
#888433
Used to be one...
1982 KZ1100-A2
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
17 Aug 2023 23:41
#888437
Following a system update several month ago it stopped working as there was a conflict. Bill has tried to resolve it but to no avail unfortunately, I can put you in touch by email if you wish?
  • Cra-z1
  • Cra-z1's Avatar
18 Aug 2023 06:33
#888445
I agree those dont look right
  • OkieZ1000
18 Aug 2023 11:49
#888455
Email would be great
