26 and 28's performance differences
- kevski
11 Apr 2023 09:35 - 11 Apr 2023 09:42
I was wondering what the performance gains and losses between 26 and 28mm pumper carbs? currently I am running 26's and am happy with the the performance, and the way they fuel is spot on, I also have a set of 28 pumpers which I have cleaned and refurbished, these are the anti tamper type which are completely stock except for the air screw, it is modified so it does not need the plug to seal it.. so what is the general pros and cons.
Last edit: 11 Apr 2023 09:42 by kevski. Reason: Added more to post.
- Warren3200gt
Re: 26 and 28's performance differences
11 Apr 2023 09:59
Following with interest Kev.
I'm no fan of CV carbs which were stock on my 1000J. I had a set of 26's so used those in my build. It ran fine with them and rev'd cleanly right through the rev range. I then changed the top end to 1100 and thought bigger carbs would be the thing to have. I bored out the 26's to 30mm and ran with those. Apart from a little bit cleaner and quicker revving I didn't really notice a difference in performance.
The next step was to add an oil cooler, now that really improved performance in all aspects!
Not sure any of the above helps or hints to answers for your question but just my experience with bigger carbs.
Be interested to see what other experienced members have to comment on the subject.
11 Apr 2023 10:25 - 11 Apr 2023 10:26I was wondering what the performance gains and losses between 26 and 28mm pumper carbs? currently I am running 26's and am happy with the the performance, and the way they fuel is spot on, I also have a set of 28 pumpers which I have cleaned and refurbished, these are the anti tamper type which are completely stock except for the air screw, it is modified so it does not need the plug to seal it.. so what is the general pros and cons.
I don't understand the bold/underlined parts. What are "anti tamper type"? And what "plug to seal it" are you referring to?
Last edit: 11 Apr 2023 10:26 by Nessism.
11 Apr 2023 11:07Lost me also 28 pumpers have air pilots that have no plug over them.I was wondering what the performance gains and losses between 26 and 28mm pumper carbs? currently I am running 26's and am happy with the the performance, and the way they fuel is spot on, I also have a set of 28 pumpers which I have cleaned and refurbished, these are the anti tamper type which are completely stock except for the air screw, it is modified so it does not need the plug to seal it.. so what is the general pros and cons.
- zed1015
11 Apr 2023 12:25 - 11 Apr 2023 12:30Some pumpers have short air screws and anti tamper caps (Welch plugs) pressed in the body so that the settings cannot be altered.Lost me also 28 pumpers have air pilots that have no plug over them.I was wondering what the performance gains and losses between 26 and 28mm pumper carbs? currently I am running 26's and am happy with the the performance, and the way they fuel is spot on, I also have a set of 28 pumpers which I have cleaned and refurbished, these are the anti tamper type which are completely stock except for the air screw, it is modified so it does not need the plug to seal it.. so what is the general pros and cons.
The caps need prising out to get at the air scrrews.
Last edit: 11 Apr 2023 12:30 by zed1015.
11 Apr 2023 12:53
These were also common place in the European car world as emmision regs got tighter in the 80's
- kevski
11 Apr 2023 22:42 - 11 Apr 2023 22:42
The air screws picture have 1 original type short air screw that was factory set and then plugged over, the other 4 are modified so they can be adjusted, as you can see instead of being threaded at the top they are threaded halfway down, the four rings are to sleeve the original plug hole so the o ring keeps it airtight, but enough about that, what of the pros and cons of 26's against 28's?
Last edit: 11 Apr 2023 22:42 by kevski.
- zed1015
12 Apr 2023 01:51On a stock motor the 28's are worth around another 7bhp and have more flow potential for a modded engine.The air screws picture have 1 original type short air screw that was factory set and then plugged over, the other 4 are modified so they can be adjusted, as you can see instead of being threaded at the top they are threaded halfway down, the four rings are to sleeve the original plug hole so the o ring keeps it airtight, but enough about that, what of the pros and cons of 26's against 28's? ]
These are the only change to the Z1R etc that upped the power from a claimed 87 to 90..
The following user(s) said Thank You: kevski
12 Apr 2023 05:14
Carbs are intended to provide roughly 15/1 air/fuel ratio. Somewhat richer at low speed and leaner at highway or higher speed.
At higher speeds the smaller diameter carbs would restrict air intake, not fuel. Fuel flow can be adjusted by changing internals so that it matches air flow. On a stock engine you would reach maximum speed sooner with the smaller carbs, and it would be lower than with the larger ones.
On my KZ1000 I installed a set of 1976 VM26SS carbs. They perform just as well as the stock VM28SS pumpers at any speed I care to travel but I suspect my top end is compromised.
12 Apr 2023 06:01
Following up on above .
Back when new My 78 LTD came with 26's
My good friends Z1R came with 28's
We raced from every traffic light and stop sign.
I was faster at the start , but he would pull on me once over about 60 mph
I jumped up to 29 smoothbores and we were even down low , but I pulled slightly on him
above 60 mph
This was before pipes , cams , gears , and all other mods happened
above 60 mph
- kevski
16 Apr 2023 07:39
I have put them on today and had to take them back off, a particle of crud had jammed a float needle, back on and running idling really well, very responsive, than the 26's crisper, working realy nicely at lower throttle, opening up under load a little bit fluffy, looking to change main jets from 102.5's o 105's, I have a set with no markings on them so if anyone knows the hole size in mm I would appreciate it if you could tell me.
16 Apr 2023 09:16
What bike are you riding?
