Identity help
- gd4now
- Denco where did you go?
Re: Identity help
09 Feb 2023 12:11
Thanks for the additional pics, but for the life of me (old eyes) can not tell if that is a air screw head in the last pic or a plug or non-drilled passage? Will say if they are from a Suzuki the ID stamped on them will begin with the number 4.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- Warren3200gt
Re: Identity help
09 Feb 2023 12:29Please Log in or Create an account to join the conversation.
- Kawboy74
Re: Identity help
09 Feb 2023 12:56
I'm wondering if they are from a '78 Z1R as they had that type of adjuster rod between 2&3 carb and a single inlet line?
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- carksz1b
Re: Identity help
09 Feb 2023 14:44
I really don’t think they are 28mm the spigot wall thickness makes me think 26mm.
Re: Identity help
09 Feb 2023 14:53
Here’s the same set, incomplete but the same speed adjuster, vacuum port on number 3 air pilots. I bet they measured the engine spigot and got over 26mm as they should and are calling them 27mm. I’m sticking with my Canadian kz1000A3 26mm
evilbay item number 374432243438
The following user(s) said Thank You: 78kawltd
Re: Identity help
09 Feb 2023 15:01
For comparison, here is a set of 28mm with pump but that doesn’t change the outlet spigot. Look at the wall thickness and compare to the OP.
Re: Identity help
09 Feb 2023 15:05
- zed1015
Re: Identity help
09 Feb 2023 16:04 - 10 Feb 2023 09:17
Those carbs ARE VM26SS.
The outlet on #3 carb is for a vacuum fuel tap so rules out all pre 1978 900's and 1000's as they all had manual fuel taps.
With the idle adjuster position underneath they are most likely 1978 Z1000A2 which had VM26SS and a vac tap unless they have both fuel and air mix screws which would make them Suzuki GS.
Last edit: 10 Feb 2023 09:17 by zed1015.
- 78kawltd
- 1978 B2, 06 Heritage Softail,
Re: Identity help
09 Feb 2023 17:03
Thank you kzriders. Due diligence x2. Thanks.
I have an inquiry into the seller from this afternoon.
Have Not heard back yet.
I asked; There should be an ID stamped below the choke lever or on the same flange on the outside of #4 carb that may help to ID the set of carbs. Can you check please ?
Re: Identity help
09 Feb 2023 18:04
Just request the ID measurement of the engine side spigot. More than 26 less then 27 you know they are VM26SS. More than 28 less than 29 they are VM28SS, but they aren’t.
- gd4now
Re: Identity help
10 Feb 2023 09:05
I look forward to what you may or may not learn from the seller.
1977 KZ650 B1
