choke on cyl 1 doesn't catch or bite the choke rod
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
03 Aug 2022 09:56
#871605
how do I remedy?
my manual doesn't show much on this
much thanks in advance
1982 KZ1100D1
  • zed1015
  • zed1015's Avatar
Re: choke on cyl 1 doesn't catch or bite the choke rod
03 Aug 2022 10:35
#871606
Pics would be helpfull.
  • TexasKZ
  • TexasKZ's Avatar
03 Aug 2022 13:28
#871621
The clamping screw for the forked lever on the choke rod may have come loose, allowing it to just slide around rather than pulling the plunger.
  • Gdailey2112
  • 82 KZ1100D1
03 Aug 2022 15:01
#871631
pics tonight, basically there is no set screw on this setup,
looks sorta like some metal ring is supposed to seat in the recessed ring or groove in the rod. its #1 carb
tried cleaning out the groove or recessed ring but im stumped.
3 chokes work and one not so much
1982 KZ1100D1
  • Nessism
  • Nessism's Avatar
03 Aug 2022 16:28
#871638
There are C-clips, along with some small springs, which secure the forked choke actuation brackets to the choke rod.
The following user(s) said Thank You: Gdailey2112
  • Gdailey2112
  • 82 KZ1100D1
06 Aug 2022 00:32
#871752
yes i harvested a c clip from another carb rack, forgot to post an update
thanx fellas
1982 KZ1100D1
