Bogging down at 55mph
- slmjim+Z1BEBE
Re: Bogging down at 55mph
11 Mar 2022 06:48
Haven't seen float level mentioned. At 55 mph. the carbs are likely to be running in the transition zone from needle jet to main jet. Low fuel level will lean out both.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Qsmothers3
13 Mar 2022 14:13
Welp, I figured it out!! Took the carbs off and low and behold one of the jets had came loose and was sitting in the bowl......put it back on and tightened it down .....problem solved...on to the main fuse blowing issue now. Thanks for all the help!
