Sr 650 EFI
  • ifranzani
  • ifranzani's Avatar Topic Author
Re: Sr 650 EFI
26 Feb 2025 15:04
#909432
Cold starting
The following user(s) said Thank You: Scirocco, Saablord, Wookie58
  • Saablord
  • Saablord's Avatar
Re: Sr 650 EFI
26 Feb 2025 20:46
#909441
It's always fun to see more of us go down the custom EFI path.
Congrats on the smooth start
  • TexasKZ
  • TexasKZ's Avatar
Re: Sr 650 EFI
27 Feb 2025 17:19
#909484
Excellent!
  • ifranzani
Re: Sr 650 EFI
29 Mar 2025 07:01 - 29 Mar 2025 07:02
#910695
Update
now with intake trumpets it does 46 hp to the wheel
red with intake trumpeters, green without (38 hp)
With conservative mapping
Last edit: 29 Mar 2025 07:02 by ifranzani.
  • TexasKZ
  • TexasKZ's Avatar
Re: Sr 650 EFI
29 Mar 2025 11:14
#910705
Wow, that is a significant increase. I wonder if a little more could be found by adjusting the length and taper of the trumpets?
  • ifranzani
Re: Sr 650 EFI
29 Mar 2025 11:48
#910708
Sure, I've only tried these trumpets
normally,
longer = more torque
shorter = more power
  • ifranzani
Re: Sr 650 EFI
29 Jan 2026 09:28
#921041
New look
  • ifranzani
Re: Sr 650 EFI
29 Jan 2026 09:29
#921042
Others
The following user(s) said Thank You: Mcdroid, sf4t7, Wookie58
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Sr 650 EFI
29 Jan 2026 11:56
#921045
Great work, how is the AFR across the rev range ? how does it ride ?
  • ifranzani
Re: Sr 650 EFI
29 Jan 2026 12:48 - 29 Jan 2026 12:48
#921047
with the accelerator at maximum arround 0.85 and idling 1-1.05
Last edit: 29 Jan 2026 12:48 by ifranzani.
  • chopper1963
  • chopper1963's Avatar
Re: Sr 650 EFI
29 Jan 2026 16:18
#921053
No fear!
The following user(s) said Thank You: ifranzani
  • chopper1963
Re: Sr 650 EFI
31 Jan 2026 09:09
#921090
I can't wait until there is a kit ...
