New 81 kz750H LTD
- Elfarm98648
Re: New 81 kz750H LTD
19 Jul 2021 23:29
Does anyone know what these wires connect to? This is my only issue with the wire harness currently. I am used to vehicle wiring where everything has an identifiable and unique plug not just little pins that could go anywhere.
- F64
- 81-KZ440D2
19 Jul 2021 23:56
Just an educated guess.
black with yellow tracer-negative ground
white with blue tracer-positive accessory connector(used if you want to add lights/phone charger..) 10 amp max
brown wire- positive wire to power lights for gauges, brake lights( check and see if all of your lights are functioning)
yellow with black tracer--not sure
81-KZ440-D2.
LIC, NY
LIC, NY
- Elfarm98648
20 Jul 2021 09:55
Okay roger on all of that. The brown wire, does it connect to the gauges or what? The bike was laid on its side so I had to order a replacement gauge set and it’s not here yet so I’m unsure if there is a brown wire that will match it on the cluster. The only light that works is the rear running light right now.
- F64
- 81-KZ440D2
20 Jul 2021 11:01 - 20 Jul 2021 12:51
brown wire is 12 volt positive when key is turned to run
the brown wire connects to:
neutral light
oil pressure warning light
low fuel warning/brake light failure light
horn
front brake light switch
rear brake light switch
turn signals
The items are above ground switched. The brown wire supplies +12V and the switch supplies the ground through another wire.
reg/rec
The brown wire appears deep maroon on the schematic.
schematic courtesy of: Mcdroid and KZJOE900
neutral light
horn
turn signals
reg/rec
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 20 Jul 2021 12:51 by F64.
- Elfarm98648
20 Jul 2021 12:16
The ground switch makes sense, I was looking over the diagram and found that out. Thanks. I’ll have to see what all the brown goes to and what it doesn’t. Thanks!
- Elfarm98648
22 Jul 2021 12:26Please Log in or Create an account to join the conversation.
