New 81 kz750H LTD
- Elfarm98648
New 81 kz750H LTD
14 Jul 2021 08:05 - 14 Jul 2021 08:10
Good morning all, first post here. I picked up a new to me 1981 KZ750H LTD for $650. Needs a lot of work but nothing I can’t handle. Upon taking it apart to clean the air box out I noticed that 2 of the air box to carburetor boots had holes in them and the filter top cover was broken. Upon some investigation into some more expensive parts, I came across the pod filters. If I install these do I need to change the jetting in the carb?
Last edit: 14 Jul 2021 08:10 by Street Fighter LTD.
Re: New 81 kz750H LTD
14 Jul 2021 08:12
Welcome to KZR
I fixed your picture to be full size
Next time click the insert all tab
Nice Bike
Nice Bike
The following user(s) said Thank You: Nessism, Elfarm98648
- ghostdive
14 Jul 2021 09:47
Any pod filters worth using will be at least the cost of fixing your airbox situation; they'll also have some drawbacks. Jetting would need altering (maybe new jets, maybe just adjusting pilot screws), your idle will be rougher, you may lose lower-end power, you'll have issues on rainy days, and crosswinds may lean out your mixture.
They do have some upsides, such as ease of installation over the airbox boots and a possibly a bit more top-end power, but my personal recommendation is new airbox boots and fix/replace the top cover.
I think I have an airbox top, but it'll be a few days until I can check/retrieve it...if you don't mind waiting it's yours.
Replacement boots here. They're not OEM but they'll be a bit more recently manufactured.
2001 ZX-6R
2001 ZX-6R
The following user(s) said Thank You: Elfarm98648
- howardhb
- God, I trust
14 Jul 2021 10:30
+1 Ghostdive
Keep everything stock standard ... least hassle, most ride-able, most reliable.
I'm in the process of putting the air-box back on my '81 GPZ550 D1
I'm done trying to get perfect mixture through the full rev range. It's good at low rpm, good above 6500... but splutters between 5500 and 6500, where it should be sweet! (highway speed 120 km/h)
I've had the carbs off at least 25 times.
I've even drilled jets ½ size up, shimmed needles with 0.25mm thick washers to get in-between needle clip postions... even tried partially restricting flow by taping closed sections of the pods with duct tabe!
I think Kawasaki engineers arrived at the best overall ballance of drive-ability / fuel economy.
my 2cents.
my 2cents.
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
- Elfarm98648
14 Jul 2021 14:06
Thank you all for the replies. I decided to take your suggestions and fix the stock air box. I would love to get that air box cover from you. Just PM me and I’ll send you my address. Thank you for the compliments on the bike as well. Many many parts coming in soon. Not soon enough though. I do have some wiring issues I hope you all can help me with.
- Elfarm98648
14 Jul 2021 14:16
For my wiring issues, it was all done by the previous owners. They dropped the bike and broke the upper triple tree, gauges clean off, headlight off, bent the handlebars, pushed one exhaust pipe into an oval and dented the tank. Other than that it’s in really good shape. Now my issues arise with my not knowing what the wires run to. I know how to use a multimeter and know how to read a wiring diagram so it shouldn’t be hard. I just want to take it back to factory instead of all of the crappy splices and cut wires you see here. All of the plugs are accounted for and should be gauge cluster and ignition key. Does anyone have a picture of what they are supposed to look like. And a diagram to go with it? Thank you for the help you have provided so far.
14 Jul 2021 16:12
Please check the "articles" tab at the top of the forum, inside you will find a link to the factory service manual for your bike.
14 Jul 2021 16:53 - 14 Jul 2021 16:54
By ghostdive: ... Replacement boots
here.
I'm pretty sure those are OEM. genuine Kawasaki ducts.
Last edit: 14 Jul 2021 16:54 by martin_csr.
- ghostdive
14 Jul 2021 17:32 - 14 Jul 2021 17:32My mistake.
I'll dig up the airbox lid next time I'm able to swing by the old place.
2001 ZX-6R
2001 ZX-6R
Last edit: 14 Jul 2021 17:32 by ghostdive.
15 Jul 2021 05:46 - 15 Jul 2021 05:51
Airbox cap. when you go to install the replacement, don't over-tighten it. The manual says to install the cap until you hear a click, but if it doesn't click any more, you could overdo it & it'll crack. don't ask how I know. hee. I tighten it until I feel the cap contact the air filter, then snug it up to compress the filter end foam.
Last edit: 15 Jul 2021 05:51 by martin_csr.
- Elfarm98648
15 Jul 2021 15:11
I wasn’t sure where to post brake questions so I figured I’d throw it out here. I’m rebuilding the whole break system as well and I was curious as to if anyone has a good replacement rear master cylinder or a quality rebuild kit? I’m powder coating all calipers and mounts, new seal kit in all of them, all new stainless steel brake lines and fittings, new front master cylinder.
- Elfarm98648
