VM26 starter circuit plunger seals
  • motoaddict
  • motoaddict's Avatar Topic Author
12 May 2021 14:25
#848360
Hi gang, so in the first photo, on the end of the choke plunger there is a small rubber seal. Are these available or should the whole thing be replaced? Some look ok while others are worn out. Can i just replace with a suitably sized o-ring?
In this second image, are the rubber throttle shaft seals available anywhere?
1976 KZ900
  • Mikaw
  • Mikaw's Avatar
Re: VM26 starter circuit plunger seals
12 May 2021 14:36 - 12 May 2021 14:38
#848361
No eBay APP ID and/or Cert ID defined in Kunena configurationPM zed1015. He replaces the plunger seals.
A little pricey
www.partzilla.com/product/suzuki/13556-4...50fda1bd702fc8e43cd5
Better
Last edit: 12 May 2021 14:38 by Mikaw.
  • zed1015
  • zed1015's Avatar
12 May 2021 14:51 - 12 May 2021 14:55
#848362
If the shaft seals are still soft and not hard and cracked they will be ok to re-use. They are only dust seals.
For the plungers, regardless of looks they will all be worn and leaking and i offer a unique re-seating service using ethanol resistant custom made Viton seats .
Originally the plungers and their seals were not a serviceable part until now.
See the Ebay link below in my sig for info but PM me for the cheaper forum member price.
Last edit: 12 May 2021 14:55 by zed1015.
  • motoaddict
15 May 2021 04:53
#848456
So I managed to replace these seals myself yesterday. Let me show you how I did it. First you dig out the old ones. I used a dental pick and they pop out pretty easily.
Then I took a suitable, gas resistant 1/16" thick rubber sheet and laser cut the correct size ring.
Then just slid them over the needle and pushed under the lip that retains it. Works great!  The seat in the carb sits tall enough to reach the seal without the lip bottoming out.
1976 KZ900
The following user(s) said Thank You: Nessism, Mikaw
  • Mikaw
  • Mikaw's Avatar
15 May 2021 07:48
#848472
Try reposting the pictures please
  • katit
  • katit's Avatar
15 May 2021 07:52
#848473
Here is my version of DIY - see end of page 10:
www.kzrider.com/forum/11-projects/615161...50-project?start=108
  • motoaddict
15 May 2021 15:02
#848501
That looks just like my hack!  Has it held up over time?   Also can you see the pics I posted because I can. Is everyone else having trouble?
1976 KZ900
  • Nessism
  • Nessism's Avatar
  • Away
15 May 2021 18:03
#848505
The photos were visible on my computer earlier but not anymore.
  • katit
  • katit's Avatar
15 May 2021 20:00
#848510
I don't see pics. I don't know if my solution will hold up, but if this material correct - I don't see why it won't
  • motoaddict
16 May 2021 18:14
#848562
what about now
1976 KZ900
  • katit
  • katit's Avatar
16 May 2021 18:51
#848564
what about now
now I see, but use "insert all" button so they are big in a post.
I also see you scratched plunger like I did with first one getting old seal out. Torch works best - old one just pops out
  • motoaddict
19 May 2021 13:59
#848740
The scratched lip will not affect performance what so ever. I just tried "insert all" did it work on your end?
1976 KZ900
