Mikuni VM26SS fuel mixture or air mixture screw? Which is it?
  • kevski
  • kevski's Avatar
Re: Mikuni VM26SS fuel mixture or air mixture screw? Which is it?
03 Oct 2020 13:21 - 04 Oct 2020 01:08
#836109
jonnydirt2 wrote: I know i am sorry i even looked at this post for help now...
As you have the carbs with the screw underneath, don't worry about other types, screws should be around 1 an 1/4 turns out, this is about right for the pilot circuit, to slightly richen screws go out, to weaken turn in slightly. This does not richen and weaken through the whole rev range.
Last edit: 04 Oct 2020 01:08 by kevski.
  • Mikaw
  • Mikaw's Avatar
03 Oct 2020 17:54
#836115
kevski wrote: As you have the carbs with the screw underneath, don't worry about other types, screws should be around 1 an 1/4 turns out, this is about right for the pilot circuit, to slightly richen screws go in, to weaken turn out slightly.
Huh???
  • krazee1
  • krazee1's Avatar
03 Oct 2020 21:23
#836118
As you have the carbs with the screw underneath, don't worry about other types, screws should be around 1 an 1/4 turns out, this is about right for the pilot circuit, to slightly richen screws go in, to weaken turn out slightly. This does not richen and weaken through the whole rev range.
"Here's the deal" (famous J.B. quote), it looks to me like this subject was well explained, with diagrams even, and then you go and post this. Are you TRYING to drive the O.P. batsh#t crazy?
Attempt at humor, please accept as such Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
  • kevski
  • kevski's Avatar
04 Oct 2020 01:05
#836123
krazee1 wrote:
K.I.S.S.
  • zed1015
  • zed1015's Avatar
04 Oct 2020 01:52 - 04 Oct 2020 01:57
#836125
kevski wrote: This does not richen and weaken through the whole rev range.
To be strictly accurate it does although hardly noticeable as a percentage.
Overall fueling is a stack up of all the circuits put together so any increase or decrease in fuel metered by the pilot screw will be added or subtracted from the total amount received elsewhere.
Last edit: 04 Oct 2020 01:57 by zed1015.
  • krazee1
  • krazee1's Avatar
04 Oct 2020 06:06
#836132
To be strictly accurate, increase or decrease in the fuel and air MIXTURE metered by the pilot screw.
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
  • krazee1
  • krazee1's Avatar
04 Oct 2020 06:13
#836133
K.I.S.S. is a good theory, but your advice is off 180 degrees. The air/fuel mixture screw on the bottom of the carbs is turned OUT to richen, (more fuel and air) and IN (less fuel and air) to lean the idle circuit.
Mike
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
  • kevski
  • kevski's Avatar
04 Oct 2020 06:18
#836134
krazee1 wrote: K.I.S.S. is a good theory, but your advice is off 180 degrees. The air/fuel mixture screw on the bottom of the carbs is turned OUT to richen, (more fuel and air) and IN (less fuel and air) to lean the idle circuit.
Mike
post already edited.
The following user(s) said Thank You: Mikaw, krazee1
  • Rick H.
  • Rick H.'s Avatar
04 Oct 2020 13:23
#836152
Dang! and here I thought I FINALLY figured out why my bike wasn't running quite right. Oh well back to the drawing board....
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Mikaw
  • Mikaw's Avatar
04 Oct 2020 19:54
#836182
Maybe this is a good time when the OP hasn't been back in a while. He missed all the Bats@#t crazy stuff.
  • kevski
  • kevski's Avatar
05 Oct 2020 00:01
#836185
Mikaw wrote: Maybe this is a good time when the OP hasn't been back in a while. He missed all the Bats@#t crazy stuff.
He probably thought f*#k it I only wanted a quick answer and not the coefficient drag factor of an issosiles triangle while eating a doughnut in the springtime.:laugh:
  • Mikaw
  • Mikaw's Avatar
05 Oct 2020 07:35
#836196
:laugh: :silly:
