Mounting the carbs with pods
- xstreamcanadian
20 Sep 2020 10:44
78 KZ 650 SR - carbs rebuilt by wiredgeorge many many years ago(still not fired up yet because I did two other bike builds since then, three actually)
I am trying to get the carbs to sit into the intakes. Is there a lube I can safely use that wont gum anything up? I can get them to seat when the intakes are off the bike, no issue, mounted intakes and the carbs wont go in that last i dont know, 1/2 inch maybe. What am I missing??? I have clamps on the intakes so loose they spin around, before anyone suggests that. I assume the clamps, once mounted are enough to hold the carbs and pods with the support of the airbox gone or do i need to fab a bracket to mount under the center valve cover bolt to the spot where the throttle cables go?
thanks i know this is probably a stupid question..
xc
xc
Re: Mounting the carbs with pods
20 Sep 2020 12:39
Any chance you have the boots mixed up? There are LH and RH boots.
- xstreamcanadian
20 Sep 2020 14:22
they dont sell RH and LH boots any more and they both work in both spots so no. What it turns out to have been is odd. I had the clamps off and they just wouldnt sit when I was attempting to dry fit them. Once i mounted with the clamps on the intakes, just loosely snugged, they popped right in. so weird. But done!!! YEAH!
- Warren3200gt
20 Sep 2020 15:27
The inlet boots are definately handed. You can tell which are which by the vacuum take off.
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
20 Sep 2020 17:53yes but...one hand, I can't remember which one, is no longer available...so if you want new , you have to flip them upside down for one side. It barely works as vacuum sync becomes a chore to set up. But, in my opinion, it is most important to have fresh soft boots that seal properly.Warren3200gt wrote: The inlet boots are definately handed. You can tell which are which by the vacuum take off.
20 Sep 2020 20:39
If I'm correct Partzilla list them as 16065-046 and 16065-047 they come up on Evilbay. Appears still available.
- xstreamcanadian
20 Sep 2020 21:50
its the LH thats not available and I dont need the vacuum lines connected up to anything they are capped off anyway. They interchange as was said. I got them mounted up at any rate
- xstreamcanadian
20 Sep 2020 21:52
agreed, it wasnt because they were hard and crunchy. mine are all brand new soft and pliable
- xstreamcanadian
20 Sep 2020 22:02Mikaw wrote: If I'm correct Partzilla list them as 16065-046 and 16065-047 they come up on Evilbay. Appears still available.
the 046 was the left hand side and doesnt come up with anything on partzilla that looks correct, the 047 is the RH one that everyone sells. they are clearly marked L and R on the factory ones
- xstreamcanadian
20 Sep 2020 22:05
Found these, be interesting to see if they fit. They look right, but we all know how that goes.
- xstreamcanadian
20 Sep 2020 22:09Please Log in or Create an account to join the conversation.
- Warren3200gt
21 Sep 2020 00:10 - 21 Sep 2020 00:15
All 650's are the same. 900 are bigger.
www.z-power.co.uk/carb-to-head-rubbers-4-z650
Last edit: 21 Sep 2020 00:15 by Warren3200gt.
The following user(s) said Thank You: xstreamcanadian
