Kz400 LTD airbox
  • robhartle82
  • robhartle82's Avatar Topic Author
Kz400 LTD airbox
18 Jul 2020 14:23
#830934
In the middle of a rebuild on a 400 LTD and am really confused about the airbox/ air filter. Where does the filter fit in the box? Or does it hook into the back by the battery where the two rectangular holes are? There's no way to actually place the filter in the airbox. And before you say it, I'm committed to not using pods on this one. Thanks for any help.
Re: Kz400 LTD airbox
18 Jul 2020 14:32 - 18 Jul 2020 20:22
#830936
It would be helpful if you were to show the YEAR of your bike. The best way is to show the year and exact model in your signature line. That way you don't need to add it every time you post. Ed
Keep in mind that Kawasaki started making the KZ400 bikes in 1974 and made them for 10 years. So it is quite likely that airbox changes were made along the way.
www.kz400.com/ModelidentificationFrameset.html
Last edit: 18 Jul 2020 20:22 by 650ed.
  • martin_csr
  • martin_csr's Avatar
18 Jul 2020 14:42 - 18 Jul 2020 14:47
#830937
Here's the airbox diagram for the 79 400-H1 Ltd. I have no idea if this is what you have. Keep in mind that the airbox cap is old & possibly fragile. Also, I believe this is a type of airbox cap that can be installed wrong & not securely. I think it's supposed to fit into a groove or grooves in the airbox.
www.partzilla.com/catalog/kawasaki/motor...kz400-h1/air-cleaner
Last edit: 18 Jul 2020 14:47 by martin_csr.
  • Nebr_Rex
  • Nebr_Rex's Avatar
18 Jul 2020 19:54
#830965
Should be the same as the KZ440 LTD.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: martin_csr
  • TexasKZ
  • TexasKZ's Avatar
  • Away
19 Jul 2020 17:02 - 19 Jul 2020 17:17
#831015
According to Partzilla, the 1974-75 KZ400D used this air filtration system-
www.partzilla.com/catalog/kawasaki/motor...r-74-75-kz400-kz400d
The 1976-77 400D used this quite different system--
The crossover chart says that the second type was also used on the 400A and 400S through 1977.
The 1979 400H1 came with yet another arrangement.
The 1979 400B2 came with this completely unique system
www.partzilla.com/catalog/kawasaki/motor...kz400-b2/air-cleaner
The 440A, D, G came with this very familiar lookin air filter assembly, but with a different part number than the similar-looking 400 model.
www.partzilla.com/catalog/kawasaki/motor...eaner-81-83-a2-a3-a4
Last edit: 19 Jul 2020 17:17 by TexasKZ.
The following user(s) said Thank You: robhartle82
  • TexasKZ
  • TexasKZ's Avatar
  • Away
19 Jul 2020 17:20 - 19 Jul 2020 17:30
#831017
If the LTD is the H model, then the filter goes into the smaller part of the air box that bolts to the upper rear part of the main box.
Last edit: 19 Jul 2020 17:30 by TexasKZ.
  • martin_csr
20 Jul 2020 05:54 - 20 Jul 2020 06:07
#831040
It should be pretty obvious where the air filter goes, so the airbox cap may be missing.
Last edit: 20 Jul 2020 06:07 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
20 Jul 2020 06:03
#831042
martin_csr wrote: It should be pretty obvious where the air filter goes, so he may be missing the airbox cap.
Indeed. I apologize for getting so carried away, but I was bored and easily got sucked into discovering how many variations there are in the 400/440 line.
  • martin_csr
20 Jul 2020 06:06 - 20 Jul 2020 06:07
#831043
No apologies necessary. my wording could've been better. hee. I just added that because it's what I was originally thinking.
  • robhartle82
23 Jul 2020 18:19
#831309
Thanks guys! Yeah it's a 79 H1 and indeed I am missing the cap. Any ideas on where to find one?? Got nothing on eBay as far as I can tell.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
24 Jul 2020 06:44
#831324
Based on conversations I have seen here, that part of the air box is pretty hard to find. Should you get a useable one, you will then be faced with designing your own filter as the original has been nla for a while. If you can come up with a workable solution, 400/440 owners (at least some of them) will sing your praises for years to come.
  • martin_csr
24 Jul 2020 07:01 - 24 Jul 2020 08:46
#831326
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's a reproduction air filter cap kit for the 440 Ltd. should be the same as the 400H Ltd.
Kinda pricey, but probably worth it & includes the air cleaner case plus a couple of oem air filter elements.
I would ask what type of plastic it is & what production process was used, so that you can assess how durable it will be.
ps: see reply by Grcko on next page. he has a cap you could get.
Last edit: 24 Jul 2020 08:46 by martin_csr.
The following user(s) said Thank You: TexasKZ, robhartle82
