Can someone identify these please?
  • Jpallison1722
  • Jpallison1722's Avatar Topic Author
26 Apr 2020 13:50 - 26 Apr 2020 13:50
#824343
Hey guys can anyone identify these Carbs for me i know they are mikuni but i cannot find a model.
Thank You!
Last edit: 26 Apr 2020 13:50 by Jpallison1722.
  • mopguy
  • mopguy's Avatar
Re: Can someone identify these please?
26 Apr 2020 14:06
#824344
Looks like
cv34mm
  • Jpallison1722
26 Apr 2020 14:35
#824348
i cannot find these carbs anywhere lol.
  • martin_csr
  • martin_csr's Avatar
26 Apr 2020 14:45 - 26 Apr 2020 14:48
#824349
Why do you need to identify a drawing?
Edit: they could be from an 82 or 83 KZ650-CSR which had Mikuni BS32 carburetors. see diagrams at Partzilla.
Last edit: 26 Apr 2020 14:48 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
26 Apr 2020 14:46 - 26 Apr 2020 14:54
#824350
Try searching Mikuni BS 34
Which year and model did they come from? Why do you want to find them?
Last edit: 26 Apr 2020 14:54 by TexasKZ.
  • TexasKZ
  • TexasKZ's Avatar
26 Apr 2020 14:55
#824351
The tops do look like 32s.
  • Jpallison1722
26 Apr 2020 15:09
#824353
I have an 83 csr 650 and im just wondering what carbs they are.
  • Jpallison1722
26 Apr 2020 15:14
#824354
Also I'm diagnosing a high idle situation i am dealing with and knowing what carbs they are might help.
  • Nessism
  • Nessism's Avatar
26 Apr 2020 16:26
#824362
Mikuni BS32's
Have you replaced the rubber intake boots that attach to the head? That's a very common location for vacuum leaks.
  • Jpallison1722
26 Apr 2020 17:21
#824364
I am working on getting that done. I have the parts but I broke a bolt on one so now i have to send the bike out to get the bolt extracted and while its out im going to have them replace the boots. I'd do it myself but i don't have a delicate touch and will probably mess it up farther.
  • martin_csr
26 Apr 2020 17:31 - 27 Apr 2020 08:12
#824366
For future reference. you should use a penetrant on some bolts & give it time to work, at least overnight in some cases. vibration with a wood block & mallet can help. Also, heat w a propane torch works on some stuff that has been removed from the motorcycle >> it depends & you have to be careful. Don't blow up the fuel tank.
Do you have the 81-83 KZ650 Kawasaki manual?
The 81-83 manual is basically the 81-82 manual plus a 1-page 83 supplement and 83 non-USA/Euro wiring diagrams.
Last edit: 27 Apr 2020 08:12 by martin_csr.
  • Jpallison1722
26 Apr 2020 17:43
#824369
i have "a" manual. I think it covers at least up to 82.
