1982 KZ750E Aftermarket Carburetors
- mbcustom
Re: 1982 KZ750E Aftermarket Carburetors
14 Feb 2020 00:49Hi,zed1015 wrote: I haven't got the part numbers in front of me but carbs from a 1000 will either be 26mm or 28mm SS.
The SC were only on the Z1 900's.
I have ordered vm28ss, which have not yet arrived, so I cannot verify directly, but by doing research I have seen that the external diameter of the mouth on the motor side should be 35mm.
My current boots have a 40mm opening, so I will have to change them.
The boots of the KZ1000 will certainly have the right opening diameter, but are the holes where the two fixing screws on the engine go in the same position?
Can I buy a kit of these to adapt the carburetors to my engine?
Thank you
- zed1015
14 Feb 2020 04:37
The bolt spacing on the 900/1000 boots are fractionally wider than the 650 but only by a mm or so and just need the holes elongating a touch..
