Problems setting fuel height
Re: Problems setting fuel height
24 May 2019 15:22
I suspect you may have the wrong float valves. Or possibly you don't have gaskets underneath them? You might try putting a thicker gasket under the part that screws into the carb. This will decrease the distance between the float needle and the float tang.
The following user(s) said Thank You: old_kaw
24 May 2019 15:32hardrockminer wrote: I suspect you may have the wrong float valves. Or possibly you don't have gaskets underneath them? You might try putting a thicker gasket under the part that screws into the carb. This will decrease the distance between the float needle and the float tang.
Aftermarket float valve seats most likely (that's why no number).
24 May 2019 18:11
Thanks for the clarification. Do you still have the old valves for comparison? I can imagine how if the new ones are quite a bit shorter, they could put the floats at an unworkable angle.
- kevski
25 May 2019 00:57
Have you set them up dry at all, that normally puts you in the ball park, i have found that new valves generally don't seat very well and i always polish them in a little,, like others have said you may have the wrong floats or valves, how long is the needle, should be around 15mm long, i have just measured a new one.
- old_kaw
25 May 2019 07:17 - 26 May 2019 07:56kevski wrote: Have you set them up dry at all, that normally puts you in the ball park, i have found that new valves generally don't seat very well and i always polish them in a little,, like others have said you may have the wrong floats or valves, how long is the needle, should be around 15mm long, i have just measured a new one.
Kevski is absolutely correct. I hardly ever exchange high quality OEM parts for cheap aftermarket substitutes. It happens all of the time cars, trucks, bikes.. AZ type cheapies will assure you of doing the same repair often, no matter what the part may be. Plug wires, brakes, etc..
My needles and seats are the originals that were in the bike when I bought it. I polished the seats with my dremel tool and if I remember right I polished the needle points in my cordless drill.
I'd be willing to bet if you polished up your old parts, they would work just fine. This way you are not putting in cheap junk in place of high quality OEM parts.
If the fuel level will not set dry, it surely will not set wet.
Attachment not found
Brass polishes up extremely well!
1981 Kawasaki Kz1000K1
Last edit: 26 May 2019 07:56 by old_kaw. Reason: typo's
- Jimwarrenuk
26 May 2019 06:07
Thanks for all the replies.
Based on the responses here and also responses from the Z1 owners club forum I think the first thing to try is genuine float valves.
I will post back in a week or so to say how it went
- old_kaw
26 May 2019 08:06 - 26 May 2019 08:07
Are the originals that far gone that they are unusable? As long as the needle spring is functioning properly, and the tip is not damaged, they can usually be polished and cleaned up to a usable condition.
The win 10 snipping tool works well for *.pdf files. (thanks Ed) This is a snipping from my service manual:
Last edit: 26 May 2019 08:07 by old_kaw. Reason: add pics
26 May 2019 08:24
On mine the seats are worn so the needle sits too close to the shoulder. Time to get new sets and they are pricey.
www.jetsrus.com/individual_parts/002_504_su.html
26 May 2019 13:59 - 26 May 2019 14:09
Jets-R-Us has a nifty table where you can figure out the Mikuni valve number. Then check out Amazon for a big saving over OEM.
www.jetsrus.com/needle_valve_float_bowl_...l_gasket_mikuni.html
www.amazon.com/VM26-26-2-0-FLOAT-VALVE/d...11&s=gateway&sr=8-30
Last edit: 26 May 2019 14:09 by Nessism.
- Jimwarrenuk
02 Jun 2019 23:32
I finally sorted the float heights using the non-original float valves.
Thanks for all the feedback on this post
Details of what I did are posted here:
Float height discussion
