81kz750 ltd
- rosko77
- Oldjeep
Is the choke on?rosko77 wrote: ok the bike is an 81 kz750h3ltd and after installing the carbs from cleaning them and backing the air screws 2 full turns upon starting now the bike shoots up to 5-6 grand and staying there i dont know what to do..i have to kill it cause it wont come dwn on rpm...all stock bike new plugs wires ignition coils
And for whatever it is worth, when I cleaned and rebuilt my carbs a few weeks ago I turned them out 2.25 turns
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
- Thank you received: 2236
The carbs were not properly adjusted before installation
-- bench synch the throttles and preliminary float adjustment.
The throttles are hanging open
-- twist grip is dirty or damaged
-- throttle cables are damaged, dirty or kinked
-- return spring is missing or broken
-- throttle shaft is damaged
There is a serious air leak
-- the carbs are not fully seated in the carb holders
-- the carb holders are old, cracked and leaking
The ignition advancer is stuck
-- rust and lack of lubrication
- Thank you received: 2829
- rosko77
- rosko77
- rosko77
- rosko77
Do you have a factory service manual? If not, you really need to get one. Check under the Articles tab on this forum to see if the one you need is there.
- undiablo
- Thank you received: 64
By the way, KZ750ltd has Keihin CV34 carbs. The screw is a fuel screw, not air. it should 2.5 turns out as the service manual recalls.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- rosko77
undiablo wrote: If you eliminate the polution system, you need to cap the vaccum carb ports.
Yes, my previous post was based on the completely unfounded assumption that the clean air system had been removed. If it is still in place, two of the vacuum ports will be connected to it, and only one will be capped. Be sure to use high quality caps as the cheap ones will dry out and begin to leak rather quickly. The factory ones are really good.
