Running rich with Pods
Re: Running rich with Pods
25 Sep 2018 14:57 - 25 Sep 2018 15:05Riddell wrote: . . . still running rich!
Float level is within spec. . . .
What about fuel level?
Last edit: 25 Sep 2018 15:05 by Patton.
- Riddell
25 Sep 2018 16:48
Has the timing advancer been checked for proper operation (not stuck in closed position)?
- bluej58
26 Sep 2018 14:50Patton wrote: Has the timing advancer been checked for proper operation (not stuck in closed position)?
A timing light would tell the tale
That bike has points right?
Have you clean and adjusted them?
78 KZ1000 A2A
- Nebr_Rex
26 Sep 2018 20:08Riddell wrote: Right! Thanks for all the suggestions.
Nebr rex, i've run all standard engine checks. Getting great compression and spark. Ive given the carbs a thorough clean and diaphragms are fine, though i did have to patch one of them with some bike repair kit stuff, hope it holds! Turns out i was wrong about the main jet, I misread an M for a 1 so the main jet is 60. Pilot is 68. Stock main is 70 so don't really want to send away for a bigger jet when I'm running rich.
With regards to the exhaust, Ive got a straight pipe connected to the old pipes which i welded into a 2-1 my self. Think they should be fine?!
SWest, The pods are brand new and clear. I used the connector boots of the stock air box between the filter and the carbs as apparently this gives a more linear air flow.
Patton, Slightly baffled by float hight! Will adjusting it change the rich/ leanness of the mixture or does it just do float bowl level. Are they linked and can i play with the hight to fix my problem as i can't find any smaller jets?
Thanks for helping guys!!
1] replace that diaphragm
2] study up on the Keihin CV carbs. There is a primary and secondary main jet.
3] for jets there is jet r us or your local Sudco dealer.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
