Idle Mixture Screw Plug
Re: Idle Mixture Screw Plug
12 Sep 2018 14:47Nessism wrote: No disrespect to Ed's link...but this copy of the manual is better...
www.750turbo.com/manuals/GPz750_Base%20Manual.pdf ..............
Thanks! I didn't have that manual, so I added that to my electronic library. Ed
- Shasta
16 Sep 2018 13:42
The parts under the Primary Main Jet are called Bleed Pipes. To get them out you need to push them out from inside the carb body. I use a sharp piece of wood dowel so as to not mark them up. Same thing for the Needle jet; push down from inside the carb throat.
Well progress! I was able to get the bleed pipes and needle jets out! However I first tried to use a pointed dowel to do this. And I ended up breaking off a piece of the dowel in both ends of one of the bleed pipes. They are stuck in there! Trying to figure out how to remove them.
1981 KZ750E
16 Sep 2018 16:09
One strand of a wire brush works well for clearing out pilot jets and jets like those bleed pipes.
