Carb ID
  • hardrockminer
  • hardrockminer's Avatar
Re: Carb ID
04 Aug 2018 12:53 - 04 Aug 2018 12:56
#788191
Here is a photo of my VM 28 SS carbs.  Note the bowls are different.  You can see the air equalizer hoses higher up on each side and the dual fuel intake lower down. Also note the accelerator pump on the botton of #2 carb.  Your carbs have the jets on the intake side but not the same bowls.  Perhaps someone changed out the bowls when they removed the pump.
Last edit: 04 Aug 2018 12:56 by hardrockminer.
The following user(s) said Thank You: lash
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Carb ID
04 Aug 2018 13:59 - 04 Aug 2018 14:41
#788192
Lash,s bowls are mikuni originals for non accelerator pump carbs. If lash's carbs measure 28mm at the outlet throat they will measure 26 at the slide as the throat tapers in.
I have a set identicle to lash's except the idle screw set up.
Last edit: 04 Aug 2018 14:41 by Warren3200gt.
  • lash
  • lash's Avatar Topic Author
Re: Carb ID
04 Aug 2018 15:34
#788200
The bowls have 100 stamped on the bottom of them also. Will these carbs be able to run on a 78 kz1000 B2 with a  little TLC ?
75 Z1B
76 KZ900A4
78 LTD 1000
  • lash
Re: Carb ID
04 Aug 2018 15:40
#788201
All the carbs are marked the same numbers at the top of this post. Sorry it took me to long to get pics.
THANKS
75 Z1B
76 KZ900A4
78 LTD 1000
  • Warren3200gt
Re: Carb ID
04 Aug 2018 15:44
#788202
Yep, should be fine. 1000 a1's and 2's had them as standard. So you should have enough fuel and air for the job.
  • hardrockminer
Re: Carb ID
04 Aug 2018 17:02
#788204
Agree that the bowls are from a non accelerator pump carb set.  But the bodies are from an accelerator set.  Notice the jet on the inlet side.
Wired George has a photo of a set just like lash's except the carbs have an accelerator pump.
www.wgcarbs.com/index.php/using-joomla/e...-vm-carb-connections
  • kevski
  • kevski's Avatar
Re: Carb ID
04 Aug 2018 23:23
#788214
Look like 28s accelerator pump,vacuum petcock type, had a set on my old A2.
  • zed1015
  • zed1015's Avatar
Re: Carb ID
05 Aug 2018 04:08
#788216
Vm26's measure around 27mm at the boot side and 28's measure around 28.6mm so these are ex Z1R/MK2 etc VM28MM pumpers with the accelerator pump function disabled by the use of stock VM 26 or 28 float bowls.
They should behave just like stock VM's as those bowls are not drilled for the fuel passage way and block off the fuel nozzles.
  • martin_csr
  • martin_csr's Avatar
Re: Carb ID
05 Aug 2018 05:15 - 05 Aug 2018 05:33
#788217
By hardrockminer:
Are those VM26 carburetors? The smooth & tall carb bodies are kind of distinctive.
You can measure them inside the carburetor bore near the throttle slides.
edited to mitigate any confusion. my mistake.
Last edit: 05 Aug 2018 05:33 by martin_csr.
The following user(s) said Thank You: hardrockminer
  • hardrockminer
Re: Carb ID
05 Aug 2018 05:21
#788218
They are 28's.  Rebuilt by WG.
  • martin_csr
Re: Carb ID
05 Aug 2018 05:32 - 05 Aug 2018 05:34
#788219
Thanks. My mistake then. I did some more checking & found them right there on WG's site. doh.
Last edit: 05 Aug 2018 05:34 by martin_csr.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Carb ID
05 Aug 2018 21:27
#788296
I have some info that indicates the ID you posted 113 over 1 are vm28ss carbs, that came stock on  KZ1000 A3 and A4
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
