1979 KZ650 ... major issues, please help!
- hostevie
18 Nov 2017 16:31 #774774
by hostevie
Replied by hostevie on topic 1979 KZ650 ... major issues, please help!
Just an update...
I replaced the diaphragm and now it's working like a charm
Thanks for all the help!
- hostevie
04 Dec 2017 16:39 #775573
by hostevie
Starting to have issues again
It revs fine in neutral, but when I put it into gear and ride it sputters and doesn't have much power.
I vac capped the petcock and carb again, and ran the petcock on Prime, but that didn't help.
Could it maybe be that the inline fuel filter is clogged? Seems like another issue where it's not getting enough fuel.
- Thank you received: 2098
04 Dec 2017 18:00 #775582
by Patton
Replied by Patton on topic 1979 KZ650 ... major issues, please help!
If not already done, would check for proper functioning of the advancer, which might possibly be stuck in the closed position and result in the reported symptoms.
Good Fortune! .
Good Fortune! .
The following user(s) said Thank You: hostevie
- hostevie
04 Dec 2017 18:51 #775584
by hostevie
New fuel filter did not help
Would that still let me rev in neutral, and only cause problems when in gear? Wouldn't it cause problems just revving in neutral too?Patton wrote: If not already done, would check for proper functioning of the advancer, which might possibly be stuck in the closed position and result in the reported symptoms.
Good Fortune! .
- hostevie
04 Dec 2017 20:04 #775586
by hostevie
I feel like it might be a vacuum leak... it starts first kick every time and idles perfectly, just bogs down under load and gives the classic lean deceleration pops.
I sprayed carb cleaner around the carb boots and I noticed a change in RPMs... it actually killed the bike one of the times. I tightened the boots down as hard as I could, but that didn't help.
Time for new boots?
Time for new boots?
- hostevie
19 Dec 2017 10:34 #776344
by hostevie
For anyone wondering, I replaced the points and condensers and it's running like new again
