Number Four Cylinder Won't Start!!
  • jdvorchak
  • jdvorchak's Avatar
Re: Number Four Cylinder Won't Start!!
05 Nov 2017 06:34 - 05 Nov 2017 06:35
#774249
How about the cheap and easy stuff first. Since you pulled everything apart did you put the spark plug wires back where they should be? If you crossed 3 and 4 it might act like you describe. Be sure your left side coil is powering 1 and 4 and right side coil is powering 2 and 3. Verify which coil is supposed to be powering which plugs. But the fact remains that one coil should be 1 and 4 and the other coil hooked to 2 and 3.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
Last edit: 05 Nov 2017 06:35 by jdvorchak.
