Problem to get gas level transmitter gas proof.
  • gordone
  • gordone's Avatar Topic Author
Re: Problem to get gas level transmitter gas proof.
18 Mar 2017 18:02
#757059
martin_csr wrote: By gordone: I also have a oring set, can try with a new one, but they are circle form and are also thicker...
The thickness of the o-ring doesn't really matter. It just needs to fit into the groove & seal against the tank. I used one from my HF o-ring kit. There were a couple of sizes that would work. Installing a round o-ring into an oblong groove takes some dexterity, but it can be done. :)
hehe, I`m not sure if the would groove, maybe it`s to tick, I will test tomorrow.
Project:
  • martin_csr
  • martin_csr's Avatar
18 Mar 2017 18:04
#757060
Maybe your o-rings are fatter than mine. ???
  • gordone
19 Mar 2017 05:44
#757098
Nessism wrote: The sensor on my 750 leaked from around the rubber grommet. I took the sensor and soaked it in a cup of gasoline for a couple of hours and the rubber swelled up and hasn't leaked since.
[IMG
I took the orginal oring in som oil for 30 minutes today, and I`m really happy with the results its not leaking any longer :)
hehe one thing fix more to come hehe :)
Thank you verry much everybody ! :)
Project:
