- Thank you received: 265
Engine will not accelerate
- KZB2 650
09 Aug 2016 15:43 #738028
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic Engine will not accelerate
Maybe search sonic cleaners on here...... been some problems with pine sol turning things black if I remember right..... you should be able to pick up some info on the best solution.
1978 KZ650 b-2
- EricTheLeg
10 Aug 2016 17:06 #738168
by EricTheLeg
The 'Honey-Do' items do cut into my motorcycling too. But then again, the "honey-didn't-do" items cut into my enjoyment of life in general, so I guess the occasional 'honey do' is a good thing.
I bought some diaphragms here ( jbmindustries.com/ ) a while back (about 2 years ago if I remember right). My prior diaphragms had small tears in them, so it was clear they needed replacing. I'm not sure I'd replace if you don't see any problems though. My symptoms were not what I'm experiencing now and what you describe.
On my bike, today I soaked the carbs using the parts cleaner that comes in a paint can from my local auto parts store (can't rember the name, wasn't Gunk). I also did clear tube test and found that one carb was filling up a bit higher than the other one. I've now got the float level adjusted to match. Both carbs fill to approx 3 MM below the top of the float bowl. I think I want to increase the fuel level a little (by 1-2 mm) next. Currently I still have troubles with pulling up off of idle.
1983 Kawasaki KZ440 LTD D/Belt - the road bike
1986 Husqvarna WR400 - the dirt bike
1985 Husqvarna WRX400 - The Project bike
Replied by EricTheLeg on topic Engine will not accelerate
Old80LTD wrote: Sorry I did not get back to anyone on this issue yet, I am in the process of redoing a bathroom.... A honey-do!
I did do the thumb test and the slides drop much slower than without anything covering the port, so here is what I was going to do, I am going to re-clean the carbs with an ultrasonic cleaner we have and then try again, if it still does not correct the issue I think that the diaphragms might be no pliable enough and might need new ones. Has anyone replaced these? What is a good source for them?
