- Thank you received: 5
81 kz550 weird running issues
- Wildman1024
wrenchmonkey wrote: I just took a pic of mine but can't seem to upload it from my phone. Ill upload it from pc here in a few minutes.
But yes, there is a screw between carb 1 & 2. Sticking straight up along front edge.
OK. Here's a pic of the screw in question. Mine has a 13mm nut on the top so it can be adjusted by hand while riding (well, pulled over but while out on the road). I don't think this nut is stock but was added by the PO.
Hope that helps!
Ok thanks for the pic. On my bike there is a slotted screw with a lock nut there. There is also another screw that appears to be a throttle stop for WOT.
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
- rrsmsw9999
- Thank you received: 67
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- loudhvx
- Thank you received: 1616
gpzweb.s3-website-us-east-1.amazonaws.co...astIdleScrewMod.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- apbling
- Thank you received: 12
Float valve was longer than the others, making
The level lower in the carb. That and a vacuum
Leak on the same carb made for a bad bad day
And some $$$.
- Wildman1024
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
- The_Proletariat
- "Cocaine is a hell of a drug"
- Thank you received: 13
Wildman1024 wrote: OK here is a little update. I performed the Fast idle mod today. What a difference that makes. Much happier now. You can start it up and not go to 7k. Adjust the choke a little and can actually ride it after a few minutes instead of having to let it warm up for 20. Much better. Thanks.
Yes it is very useful. I have found that in the spring/fall (cooler temperatures) I need to increase the fast idle. During the summer heat I need to decrease the fast idle.
I would like to ask Loudhvx: How do you press a nut onto an allen head bolt? I would like to do this so I don't have to carry an 8mm wrench.
1982 Kawasaki KZ550 LTD
- Wildman1024
I believe the nut size I used was 3/8. I used my bench vise to press them together.
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- The_Proletariat
