1982 ZZ750 wont run????
  • jcurriert
  • jcurriert's Avatar Topic Author
Re: 1982 ZZ750 wont run????
15 Jun 2016 08:29
#731490
oh man rookie mistake..... lol
the throttle cable wasn't loosened off all the way. i thought that backing off the ilde adjestment would show me closed throttle... thats tru but the cable wasn't allowing it to close all the way. I also was takeing for granted the jam nut on the cable was set right. It wasnt lol
not sure if that was the beers or i missed that in a rush to see it start. lol
****fixed now and running.. some poping out the exhaust because of the stait pipes but ill get that tidied up.
thx for all your help.
-Black 1981 KZ750 LTD (Sold)
-Met. Blue 1982 KZ750 LTD(currently fixing)
-Blue 1982 KZ750 LTD parts bike (parting out)
15 Jun 2016 08:54 - 15 Jun 2016 08:55
#731497
Valve clearances (a/k/a "lash") should indeed be checked and adjusted as needed; however, too tight valve clearances would more likely be expected to result in poor idle or failure to idle, especially at normal operating temperatures. Often noticed when the engine fails to hold an idle while the bike is stopped and is supposed to sit there idling (but doesn't).
Poor carb sync would be expected to result in a rough idle (along with additional obnoxious cam chain noise) , but not necessarily altogether prevent an idle or cause a racing idle.
Good fortune! :)
Last edit: 15 Jun 2016 08:55 by Patton.
  • TexasKZ
  • TexasKZ's Avatar
15 Jun 2016 17:24
#731565
There is a really good tutorial on checking and adjusting valve lash in the factory service manual. As mentioned before, adjusting the carbs without knowing that the valve lash is correct, may prove to be a big waste of time. Also, getting the carbs to work well with straight pipes may prove to be very frustrating and time consuming.
