How far to screw carb jets. 78 kz750
  • kanexx
  • kanexx's Avatar
Re: How far to screw carb jets. 78 kz750
24 Oct 2024 19:50
#905421
20241024_182930
  • zed1015
  • zed1015's Avatar
  • Away
25 Oct 2024 05:09
#905427
I have the same set up as you , i finally got it to idle great now I need to get it to run good after I let up from wot. After I let up on throttle it revs high and I will down shift and then up shift the it  settles down , but every time I open up does the same thing, any ideas ? Thank you
kane
You may be waiting a while for a response from Randombeat.
This thread is nine years old and the OP hasn't been active here since 2021..
The following user(s) said Thank You: Injected
