KZ440 - A can't seem to get running
  • ttfraz
  • ttfraz's Avatar Topic Author
Re: KZ440 - A can't seem to get running
27 Aug 2015 12:53
#687355
No ideas??????
1980 KZ440-A1 LTD
  • missionkz
  • missionkz's Avatar
27 Aug 2015 16:06
#687378
Pulsing is typically associated with an air leak on the engine side of the carbs.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • ttfraz
27 Aug 2015 16:32
#687383
Do you mean coming in from the exhaust. Or as in a gasket leak?
1980 KZ440-A1 LTD
  • missionkz
27 Aug 2015 17:23
#687393
With the throttle closed and the engine idling, there is a very strong low pressure between the intake valve, the carb's slides (or butterfly, as the case may be) and that low pressure is exposed to anything in between the two... like an air leak. Standard atmospheric pressure will try and fill that vacuum.
So, if there is any kind of an air leak between the two.... the idle mixture goes lean. Since the idle mixtures can be a bit rich to keep it ticking over at low speeds, an air leak can momentarily speed the engine up and advance the mechanical ignition timing which can speed the engine a bit too.
And when the mass of air flow and mixture rushes in, that fuel mixture gets used up faster and the engine slows down again, retarding the timing a bit... etc etc ...starting the whole process over again.
It should not be crazy jump in RPM just a few hundred RPM pulse up and down.
However, as I think about it, it sounds a bit more like a combination of carbs out of sync, idle speed is incorrect and the idle mixture screws not set the proper idle condition mixture.
Bruce
1977 KZ1000A1
The following user(s) said Thank You: ttfraz
  • ttfraz
27 Aug 2015 17:29
#687396
Thanks I'll try syncing the tomorrow and see how it goes.
1980 KZ440-A1 LTD
