How the heck do I remove the carburetors?
- baldy110
Re: How the heck do I remove the carburetors?
16 Apr 2015 12:23
If the hoses are all stiff and hard then I have had good luck using a hairdryer set on high to warm up the rubber and makes them plyable again.
16 Apr 2015 15:54 - 16 Apr 2015 15:55
Isn't the heat trick just a temporary fix for removal & installation of stuff?
I used hot water on a duct to make it soft for re-installation,
but it hardened again after it cooled down. doh.
Last edit: 16 Apr 2015 15:55 by martin_csr.
- mopguy
16 Apr 2015 17:11
I remember reading somewhere here that you can soak these hard rubber in a solution of ( I cant remember what ) and it will make them soft and pliable again.
16 Apr 2015 18:48
Xylene & mineral oil or maybe wintergreen oil. ???
Not the xylene concoction, but I've done long term tests w brake fluid, pine sol, stp leak stop, & a few others --- the rubber softens some, but re-hardens within days.
The following user(s) said Thank You: Randombeat
- murquiza
17 Apr 2015 12:55martin_csr wrote: Xylene & mineral oil or maybe wintergreen oil. ???
I tried that in that past, is not worth the effort, the boots where not that expensive from partzilla and find wintergreen oil made me drive a lot and spend a lot of time. And as Martin said they will harden within a few days and the bike smells weird.
Warming them up and a lot of patience works the best.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
