Individual Air Filters on a 82 KZ550C LTD
  • martin_csr
  • martin_csr's Avatar
Re: Re:Individual Air Filters on a 82 KZ550C LTD
29 Mar 2015 05:23 - 29 Mar 2015 05:27
#665614
Doesn't his bike have mechanical slide carburetors? KZRider loudvhx may have jetting info for TK-22 carbs on his motorcycle stuff page --- links available in his signature.
PS: if you don't know the age of the rear brake shoes, replace them. The adhesive that binds the linings to the shoes can fail over time, so a lining can come loose & get jammed between a shoe & drum, locking the rear wheel. It happened to me so it does happen. doh.
Last edit: 29 Mar 2015 05:27 by martin_csr.
  • Tyrell Corp
  • Tyrell Corp's Avatar
30 Mar 2015 09:02
#665782
Much easier tuning for pods if you have slide carbs, CV's are a lot more sensitive.
My guess would be one size up on the main jet and maybe tweak the needle height, tune top down, get your WOT main jet size first.
  • aarb77
  • aarb77's Avatar Topic Author
04 Apr 2015 07:13
#666488
Thanks for all the great replies. Martin, I have broke down everything and putting new on for the build...brakes, bearings, ect.
RB
  • 78kzturbo
  • 78kzturbo's Avatar
Re: Individual Air Filters on a 82 KZ550C LTD
04 Apr 2015 16:53
#666556
Do you know the jet sizes? it looks to be 32 pilots and 92 and main jets if this is correct let me know. If you decide to go to individual air filters i will help you with jetting. i worked for a cycle shop for many years and jetted all kinds of bikes including these ones with the tk carbs. I myself prefer individaul filters i like to bring in as much air as possible and add some fuel. However If your a hardcore rider that rides in the rain then individual air filters is not for you.
  • aarb77
04 Apr 2015 17:07
#666561
Thanks turbo! It ia a 32 pilot and 92 main. I will not be driving in the rain on this bike so I should be good. I have a rebuild kit that they gave me with the bike and the pilot needle can be raised higher. The kit has a new set of 92 main jets. I can drill these out on the mill at work. One question I do have in the process of cleaning the carbs I noticed that the idle mixture screw is capped and the manual says when cleaning remove cap/plug clean and then replace the plug. Is it necessary to replug?
RB
  • floivanus
  • floivanus's Avatar
04 Apr 2015 17:14
#666563
Shouldnt need to replug it's so you dont mess with them... Kind of bs item.
Everyone used to do it; honda, Suzuki, yamaha, chevy, ford, mopar. Just to lean the carbs out for emissions standards.
Past; 78 kz1000, 83 kz550
Andrew
  • 78kzturbo
04 Apr 2015 17:31
#666565
I would not mess with the plugs. I always hated getting a set of carbs to work on were they was removed. They are set from the factory its a good sign that no ones ever messed with them. As far as jetting goes i would go with 34 pilots and 102 main jets. This will get you right in the ball park. I would not drill out the jets they are almost impossible to drill them all equally. The needles should have 5 adjustments i would set somewhere in the middle. hope this helps.thanks dave
04 Apr 2015 17:56
#666568
I wouldn't drill them. Ed
  • aarb77
04 Apr 2015 18:15
#666573
Thanks turbo and ed.
RB
  • aarb77
06 Apr 2015 14:20
#666830
Tutbo, do you know if the 34 pilot and 102 main is the stage 3 Dynojet kit?
RB
  • catastrophe621
  • catastrophe621's Avatar
19 Apr 2015 22:36
#668818
my stage 3 kit came with 98 102 108 and 112 and needles with 6 clicks that are longer then the stock needles... anyone with any ideas on where to start would be great I was running the 112 at 3rd click but then I had the carb cleaned by the local shop and that is no longer the case.. im working this out right now myself
