Airbox boot repair?
- NewYorKZ440
Re: Airbox boot repair?
20 May 2016 09:33AtLarge wrote: You might want to Google 'Moog mod' and save some trouble.
would the moog mod work for an 83 kz440 d1 ?
- AtLarge
21 May 2016 06:15
Can't say for sure without doing a little research on your part. The later model 750 twin had BS34 carbs so I would expect yours are slightly smaller. Also, the 750 airbox had rings that would allow the bellows to be clamped in securely. I don't see that on yours and you would want a tight fit without air leaks or it defeats the purpose. I would imagine there are smaller rack and pinion boots out there or you might even get by with front fork boots from a smaller dirt bike but again, you would have to look around to find sizes compatible. A force fit with the softest radiator hose cut down may be your only hope.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
