- Thank you received: 10
Jet Kit Availability?
- OutsiderKZ900A4
- missionkz
There should be some vent tubes connected to the little spigots and run down towards the ground.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- gd4now
- Denco where did you go?
- Thank you received: 443
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- OutsiderKZ900A4
missionkz wrote: I think those are atmospheric pressure vents so the float bowls don't "lock up" in a vacuum as the fuel level drops and bounces around... etc.
This is good to know, thank you!
- OutsiderKZ900A4
gd4now wrote: Those are bowl vents and have to remain open - as missionkz indicated.
Thank you as well!
- Jeff.Saunders
one coil feeds #1 & #4 cylinder, the other coils #2 & #3.
www.z1enterprises.com
Z1 Ent on Facebook,
- F1schumie
- Thank you received: 2
or
Just get a new $20 front sprocket and ride
swap it out in 10 mins whenever your ride dictates.. smooth running carbs are a key to enjoy the KZ/GPZ..
J
