"Easy way" to clean carbs?
  • bountyhunter
  • bountyhunter's Avatar
Re: "Easy way" to clean carbs?
22 Jun 2014 14:03
#637548
Mine is similar. Kluged together from parts I had in my toolbox.
  • Nessism
  • Nessism's Avatar
22 Jun 2014 17:08 - 22 Jun 2014 19:08
#637570
650ed wrote: Like I mentioned, if you pull parts (jets, etc.) out of the carbs to clean them make sure each part goes back into the same carb from which it came. Don't do like that guy and mix them between carbs. Ed
Only parts I bother to keep together is the slide with the body, and float needle with the matching seat. I don't worry about the jets and other parts.
Last edit: 22 Jun 2014 19:08 by Nessism.
