79 KZ650 Loss of Power, Engine Quits
- BigFreakD
Re: 79 KZ650 Loss of Power, Engine Quits
09 Jul 2014 11:19
Make sure you check the ohms on your current coils and get the same rating
Treat people with respect, until they prove they shouldn't be.
2007 Kawasaki 1600 Mean Streak (totaled)
2013 Yamaha FZ6R (Wife's current bike)
1981 KZ750 (Finishing up Cafe Racer)
1979 KZ1000J (Waiting on restore)
1982 KZ1000J (Being restored to sell)
- oldzed
09 Jul 2014 16:14
have you by any chance checked your charging circuit?
I had a similar problem and found that at higher revs my alternator was not charging properly.
The voltage at tickover was 12.5volts but only 10volts at 4000rpm.
the coils were not firing properly at low voltage
- bikerdave79
25 May 2015 10:09
I just had this exact same problem. The point condensor were hot soaking and failing causing the coils to fart out. Replace the points and condensers and problem solved
