78 KZ400B Tuning Help
30 May 2014 12:52 - 30 May 2014 12:52 #634655 by treitz
78 KZ400B Tuning Help was created by treitz
I'm working on a KZ400B for a friend of a friend. I worked on the stock carbs on my KZ400 for about 2 years before I finally gave up and went 2-1. Anyway, this bike is completely stock so he wants to stick with the stock carbs if possible.
Here is where I am at after about 4 hours of tuning, and $150 in parts...
Exhaust: Stock
Intake/filter: Stock
Jets:
Pilot = 35 (stock)
Main = 70 (stock)
Secondary = 95 (stock = 90) Note: This was jetted up by someone else. Not sure why.
The stock petcock is leaky, so the first thing I did was replaced it with a aftermarket non-vacuum type. At the same time I capped off the vacuum nipple on the carb. I replaced both diaphragms because one was sticking ope (Wrong part installed by some idiot). Carb holders were leaky, so I replaced those two. Checked float level and everything looks good.
All of this said you would think the bike would run like stock. Wrong.
Bike starts up, runs fine off of idle for a bit but bogs majorly at anything above full throttle. Maybe that jetted up secondary is the issue here?
Then if I try taking it for a spin it just bogs, bogs, and bogs some more. Acts like it's getting fuel but not any air.
Like I said, I haven't messed with CV style carbs in a while. Could the capped off nipple be forcing the slides to not slide with increased throttle? I forget how the diaphragms actually operate.
My only other thought is replacing the petcock with a stock vacuum style replacement, and jetting that secondary back down. Just don't want to waste my time if neither of those are likely the issue.
Any input at all appreciated.
1979 KZ400 - 2-1 Manifold - Mikuni VM34
Last edit: 30 May 2014 12:52 by treitz.
30 May 2014 12:59 #634657 by Cynjut
Replied by Cynjut on topic 78 KZ400B Tuning Help
I think your instincts are good. I wouldn't mess around with the fuel system, assuming the inside of the tank is clean, you have a low-pressure in-line filter, and there;s nothing clogging up the works.
Check the spark.
If you haven't done so, check the timing.
Make sure the mechanical advancer is working correctly.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
30 May 2014 13:05 #634659 by Patton
Replied by Patton on topic 78 KZ400B Tuning Help
If not already done, would perform the clear tube test to assure fuel levels are within specs.
Good Fortune! :)
30 May 2014 13:11 #634661 by 650ed
Replied by 650ed on topic 78 KZ400B Tuning Help
When is the last time the advancer was cleaned/lubed and new points/condenser installed? If the ignition points, advancer, and timing are not up to snuff the engine will bog. Ed
30 May 2014 13:20 #634666 by treitz
Replied by treitz on topic 78 KZ400B Tuning Help
Thanks for the input guys. I did check spark before I started, but the points and condenser looked like they could use a replacement. Maybe I will start there.
Should I put the gravity petcock back on and cap off the vacuum nipple again, or would you advise a replacement OEM style petcock?
30 May 2014 13:48 #634671 by Cynjut
That's a personal preference question. Both have their obvious advantages.
1977 KZ-1000 A1
30 May 2014 13:58 #634675 by treitz
Cynjut wrote: That's a personal preference question. Both have their obvious advantages.
I prefer the gravity feed. Just want to make sure that capping off the vacuum nipple isn't causing issues. I've done it before without issue, so I don't think that is where my problem lies.
30 May 2014 14:38 - 30 May 2014 14:47 #634681 by Tyler
Replied by Tyler on topic 78 KZ400B Tuning Help
Ok did you check the pilot system? When you pulled the pilot jet did you remove the brass pitot tube that feeds gas up into the carb ? The early carbs may different, the factory changed that pilot system a few times. But that little tube has a bunch of tiny holes cross drilled in it and often can gunk up and starve the pilot circuit.
I found with my 440 that those CV carbs are very touchy, but the run very well if you are thorough in cleaning them. 90% of the time the pilot circuit is problem. Also is the air filter intact? If that has been messed with the bike won't run for $hit.
Oh yeah one more tricky point to the carbs, some of them have a plastic plug over the pilot jet with a small cross hole drilled to pick up fuel from the near by main jet, if those carbs were supposed to have the plugs over the pilot jets the bike will flood out. Again Kawasaki changed that a few times too...
Lastly capping the vacuum port for the pet cock will not affect the operation of the diaphragms.
"74 Yamaha DT 400 Enduro
Last edit: 30 May 2014 14:47 by Tyler.
30 May 2014 14:58 #634687 by Tyler
Here is picture of the type with the capped pilot jets... don't know when this change was made
Attachment 28126_640.jpg not found
30 May 2014 15:26 #634692 by treitz
My 79 KZ400 had the caps on the pilot system. These do not. However if they are SUPPOSE to have that cap, that would explain a lot wouldn't it?
30 May 2014 16:32 - 30 May 2014 16:34 #634699 by Tyler
I left those off on purpose once, and any throttle would immediately flood the bike. If you see a small hole drilled from the pilot jet casting over to the secondary jet, then chances are it was supposed to have them.
Last edit: 30 May 2014 16:34 by Tyler.
30 May 2014 18:45 #634719 by treitz
According to the book I think it is suppose to have them. Now the hard part is finding replacements.
