Removing the carburetor from a kz400
- Nebr_Rex
Re: Removing the carburetor from a kz400
20 Apr 2014 07:33
Late model 400.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
20 Apr 2014 07:34
440.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
20 Apr 2014 07:58
Could not find any 440 air box boots. You will have to compair part numbers between
the 440 and KZ750/4 H and E models. The 440 uses a CV36 and the 750s use a CV34.
Carb body casting is the same between the two on the outside. Only difference is the
throttle blade and venturi. The CV36 is cast larger. All other parts interchange
including the diaphragm.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
20 Apr 2014 10:43 - 20 Apr 2014 10:44
Last photo of topic post, the frame appears to be a 440. To pin down what model it is, you can try checking the engine & frame number info at CycleChaos.com -->> list of Kawasaki motorcycles.
Last edit: 20 Apr 2014 10:44 by martin_csr.
