Carb cleaning
  • eric77kz
  • eric77kz's Avatar Topic Author
Re: Carb cleaning
29 Apr 2014 22:33
#630872
Ah Ha! OK. That would make life easier.
77 KZ650 C
  • eric77kz
Re: Carb cleaning
30 Apr 2014 02:30 - 30 Apr 2014 02:32
#630878
Any tips or how to's on removing/replacing the airducts? They are rock hard! Once again I am a novice so thanks for the patience.
77 KZ650 C
Last edit: 30 Apr 2014 02:32 by eric77kz.
  • undiablo
  • undiablo's Avatar
Re: Carb cleaning
30 Apr 2014 05:07 - 30 Apr 2014 05:07
#630884
Blow them with hot air (hair dryer or heat gun), this will soften the old rubber. When re-installing it is better to submerge them in hot water (use gloves).
The better solution is to buy new ones.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 30 Apr 2014 05:07 by undiablo.
Re: Carb cleaning
30 Apr 2014 05:08
#630885
Replace the air duct with new ones. New ones are quite pliable and they make the task 1000 times easier. Ed
  • eric77kz
Re: Carb cleaning
30 Apr 2014 07:34 - 30 Apr 2014 08:34
#630905
Ok I might need a little more "hand holding" through this. I went to Z1 and there were several options for ducts. A few said they would not work for certain types. with the pics I have shown and your vast knowledge could someone be specific on which ones I need? You guys are great and I would be up a creek without ya! I promise to share what I learn through my journey. Are these right?
77 KZ650 C
Last edit: 30 Apr 2014 08:34 by eric77kz.
Re: Carb cleaning
30 Apr 2014 08:51 - 30 Apr 2014 08:59
#630912
No; those are not the correct ones for your 1977 KZ650-C1. The correct ones are shown in the diagram below. The good news is that Kawasaki still lists them as "Active" so any dealer can order them for you. Partzilla lists them at $7.87 each for 11015-057 and $11.86 each for 11015-063. Around $40 for the full set. Ed
www.partzilla.com/search/?q=11015-057&x=4&y=11
www.partzilla.com/search/?q=11015-063&x=9&y=10
Attachment 00006_2014-04-30.jpg not found
Last edit: 30 Apr 2014 08:59 by 650ed.
  • nickleo373
  • nickleo373's Avatar
Re: Carb cleaning
30 Apr 2014 08:55
#630913
Z1 has a search function where you can choose your exact model and it will only show you the parts that will fit
1981 KZ550C LTD
"If you ain't first, you're last"
  • martin_csr
  • martin_csr's Avatar
Re: Carb cleaning
30 Apr 2014 09:18 - 30 Apr 2014 09:20
#630917
In general that is correct, but not 100%.
In this case yes (but for my 81 650H, the wrong ducts are listed... the correct ones are NLA).
Z1Enterprises -->> By Model -->> Kawasaki -->> KZ650-C1 1977 -->> Carb -->> the 1st item listed shows the correct ducts for the 1980 & earlier 650s. click!
Last edit: 30 Apr 2014 09:20 by martin_csr.
