83 kz550 now starts but idles way too high.
  • Gordo5000
  • Gordo5000's Avatar Topic Author
28 Mar 2014 17:34 - 29 Mar 2014 15:13
#626934
Okay so I got the bike started but it idles at what seems like full throttle. The idle adjustment is all the way out so the butterflies should be closed, the air fuel mixture screws (pilot screws) are at 1 and 1/4. My intake boots are tightened and my vacuums are all capped off except the one that goes to my petcock. Anyone have an idea why it's idling so high. Anything would be appreciated.
1983 kz550 Spectre
Last edit: 29 Mar 2014 15:13 by Gordo5000.
  • nickleo373
  • nickleo373's Avatar
Re: 83 kz550 Carb not drawing fuel to cylinders
28 Mar 2014 17:40
#626935
Are you using the stock air box or pod filers?
1981 KZ550C LTD
"If you ain't first, you're last"
  • Gordo5000
28 Mar 2014 17:47
#626937
I'm using the stock air box
1983 kz550 Spectre
  • nickleo373
28 Mar 2014 17:58 - 28 Mar 2014 17:59
#626938
The plugs that I believe you're talking about are fuel/air mixture screws. If you have a US model they should be capped off. If they have been drilled out it means a previous owner has probably adjusted it for some reason. A good place to start is by lightly seating the screws and then turning them 2-2.5 turns out. I would also check your fuel level in the carbs using the clear tube test
1981 KZ550C LTD
Last edit: 28 Mar 2014 17:59 by nickleo373.
The following user(s) said Thank You: Gordo5000
  • Gordo5000
28 Mar 2014 18:16
#626939
The caps have been removed on my bike for the fuel/air mixture screws, but I have them set at about 1 and 1/4 turns out, so tomorrow I will turn them out further and give it a shot. The plugs I mentioned are what I believe to be rubber and sit over the pilot jet, number 92055 on the carburetor parts schematic www.cmsnl.com/kawasaki-1983-kz550-h2-gpz.../partslist/6841.html .
Thank you for your responses also.
1983 kz550 Spectre
  • Gordo5000
Re: 83 kz550 now starts but idles way too high.
29 Mar 2014 16:41
#627027
Anybody have any idea?
1983 kz550 Spectre
29 Mar 2014 18:10 - 29 Mar 2014 18:19
#627033
Perhaps the throttle cable or carb throttle assembly is binding for whatever reason. Could manually hold the carbs closed to see whether it makes any difference.
If not already done, would also use a strobe type timing light to visually inspect and confirm proper functioning of the timing advancer (which might be stuck in the advanced position and thereby failing to return to its closed idle position when the throttle is closed).
There might also be an air leak -- somewhere, for whatever reason -- that's causing a racing idle.
Check for:
• defective plugs on the vacuum nipples,
• loose carb holder clamps,
• torn carb holder,
• carbs not fully seated into the carb holders,
• a cracked or loose vacuum hose connection at either end,
• leak incident to clean air system,
• cracked worn out carb holders,
• missing or damaged o'rings on pilot adjustment screws,
• etc.
With engine running, can spray WD40 about the carb holders and any other suspected air leak sources to determine whether the WD40 is being ingested to affect the idle speed and/or cause smoke from the exhaust.
WD40 is a little messier than other type sprays such as carb cleaner or propane gas, but WD40 most clearly indicates evidence of an air leak, especially the exhaust smoking.
Good Fortune! :)
Last edit: 29 Mar 2014 18:19 by Patton.
29 Mar 2014 19:29
#627041
I would start by disconnecting the throttle cable at the carbs. If you do that and the engine still idles high you will know for sure that the problem is in the carbs and not the cable or handlebar throttle. If it idles normal you will know the problem is in the cable or handlebar throttle. Ed
  • Gordo5000
01 Apr 2014 16:09
#627458
Let me start by saying thank you guys for posting I really appreciate it, and I am sorry for the delay in responding. College/Work plus the wife keep me on my toes. Ok here is the update: I checked the throttle cable and it has some play, and when released it functions correctly with no binding. I let the bike sit for a day and went and started it and had to use the choke to get it fired up and it seemed to idle okay for a short amount of time( maybe 4-5 minutes) and then it started going higher and higher to the point where I killed it because it sounded like it was at full throttle. Also when it started to increase in idle I took some wd-40 and sprayed it around my boots going to the airbox, my intake boots, and my vacuum nipples and it seemed to have no effect. So I Guess my question's would be is that consistent with an air leak still? or is that a symptom of the stuck timing advancer? Or does anybody have some more insight as to what I might check into?
Thanks in advance.
1983 kz550 Spectre
  • nickleo373
01 Apr 2014 17:21 - 01 Apr 2014 17:22
#627467
Also make sure you are spraying at the vacuum port on your petcock and the clean air emissions unit underneath your gas tank attached to your valve cover (if you have that). Those are both fairly common places for a vacuum leak. I've found that wd40 isn't the best thing to use for finding the leaks because it doesn't cause the engine to make a huge noticeable difference in idle. I would suggest using carb cleaner.
1981 KZ550C LTD
Last edit: 01 Apr 2014 17:22 by nickleo373.
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
02 Apr 2014 06:01
#627507
Hey Gordo! No expert here, but thought I would throw this out there...My 650 (when cold) needs to start on choke...It will rev like crazy if you walk away as it is warming up...I progressively "feather" the choke down for mebbe a minute until she is fairly warm, and idling normally...Re: spraying carb cleaner around airbox boots/carb mounts, etc...this test really needs to be done at as low an rpm as you can establish...at idle, the vacuum is much higher and will draw the vapors in much more readily.
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • stagchr
  • stagchr's Avatar
02 Jun 2014 22:32
#635093
I ran into the same issue. I'm not pretending to know what I'm doing, but the choke was sticking - (gotta love Nebraska dust!) when the choke is fully open, it manually opens the throttle just a little. I was able to free mine up with some Seafoam and patience; just worked the choke back and forth until it leveled out.
Good luck!
Lincoln, NE
1981 KZ550C
1982 KZ305 CSR (once upon a time)
\\\\\\\"Is that helmet full of idiot? Why is it on your shoulders?\\\\\\\"
