Any Tricks to get the carbs back on?
- Mid life crisis
Re: Any Tricks to get the carbs back on?
26 Aug 2013 20:20
Yeah, I figured there wasn't any magic ways. The pick is a good idea. I was trying to use a flat head screwdriver blade. It eventually worked, but the 90 degree bend would have made it much easier.
Thanks.
Thanks.
- 74ullc
26 Aug 2013 21:29
I just bought new OEM boots from Z1E for my '77 KZ1000. These new boots are much softer than the old dried up stiff originals. I have my carbs out to rejet and am going to be putting them back on in a few minutes.
Based on how soft these new ones are I think the trick is to get new boots if available.
I thought about rolling the ends over but I'm not sure even the new ones will take that without ripping? On my bike pulling the boots back inside the airbox is not an option. The boots get sandwiched between the inner mesh baskets and a flange. As far as I can tell this all must be assembled before putting the airbox back into the bike.
It would be interesting to see how the factory assembly line handled carb/airbox install. They must have had a good method.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
- Mid life crisis
26 Aug 2013 23:12
I was thinking about factory assembly as well. I wish I could have access to the carb-putter-in machine!!
- JR
26 Aug 2013 23:2974ullc wrote: .........................
I thought about rolling the ends over but I'm not sure even the new ones will take that without ripping? ........................................
New soft boots fold back on themselves so easily that it seems they were designed with this in mind
Doing this I can remove and replace my carbs almost as fast as when I had pods
