Fuel Petcock PRI
  • nickleo373
  • nickleo373's Avatar Topic Author
Re: Fuel Petcock PRI
31 Jul 2013 21:10
#599315
Ok so i looked at the vacuum hose and there aren't any rips in it however i did notice that when i touched the float bowl drains there is a tiny amount of gas leaking from them. Its not a visible amount but it is enough to leave that cool gas feeling on your hands. Ive recently replaced all the gaskets in my carbs and I'm not sure what would cause it to leak from its float bowl drains
1981 KZ550C LTD
"If you ain't first, you're last"
31 Jul 2013 22:17
#599332
nickleo373 wrote: On tk22 carbs i believe there is only one hole where the vacuum hose can attach to....
May use any one of the 4 sync nipples located on the carb holders as a vac supply for the petcock. Remember to cap/plug the dedicated carb vac nipple.
Good Fortune! :)
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
01 Aug 2013 08:06
#599377
nickleo373 wrote: Ok so i looked at the vacuum hose and there aren't any rips in it however i did notice that when i touched the float bowl drains there is a tiny amount of gas leaking from them. Its not a visible amount but it is enough to leave that cool gas feeling on your hands. Ive recently replaced all the gaskets in my carbs and I'm not sure what would cause it to leak from its float bowl drains
Maybe the floats were set to a incorect height. Maybe needle and seat leaking.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
01 Aug 2013 09:00
#599384
nickleo373 wrote: ... did notice that when i touched the float bowl drains there is a tiny amount of gas leaking from them. Its not a visible amount but it is enough to leave that cool gas feeling on your hands. Ive recently replaced all the gaskets in my carbs and I'm not sure what would cause it to leak from its float bowl drains
Would replace all drain screw o'rings.
Good Fortune! :)
  • nickleo373
06 Aug 2013 18:03
#600119
I ended up taking the carbs off the bike and doing a full cleaning with carb spray and compressed air. I readjusted the float heights back to stock. The previous owner apparently thought he could make up for not rejetting the carbs for pods by changing the float height. :S I got everything put back on the bike and it's running much better. The only problem I'm having now is the petcock doesn't seem to be delivering gas into the carbs in the on or res position. It was probably doing this before I took the carbs off but it was running so poorly I didn't notice. I figure it's probably a vacuum problem because it's a vacuum activated petcock. I can't find any rips in the vacuum hose that would be causing this. Does anyone have any ideas?
1981 KZ550C LTD
  • Powerstroke_fan
06 Aug 2013 18:16
#600120
Make sure you have the hose hooked up to carbs correctly. if you are sure you do you could always test the petcock by unhooking the vacuum line and putting a suction on it and see if it opens.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
06 Aug 2013 18:20
#600121
Like powerstroke_fan said almost a week ago... ;)
Powerstroke_fan wrote: It sounds like to me your not getting proper vaccum or the diaphram in the petcock is bad.
06 Aug 2013 18:20
#600122
Is possible the petcock diaphragm valve assembly (7) or fuel tap gasket (3) is damaged? Ed
Attachment 00000_2013-08-06-2.jpg not found
06 Aug 2013 20:23
#600145
Would get a kit and rebuild the petcock.
Setting float height is futile unless true fuel level is confirmed within specs via the clear tube test.
Good Fortune! :)
