pingle petcock conversion for 81 650csr
- jbalet666
im in the process of replacing it and thought maybe converting it to a pingle petcock might be benificial (ie. its more simple less problematic)
anybody do this or no that its possible with out any modification (besides the obvious difference in mouting it, i have a plan for that )
81 650csr
AoA
old soul young blood
- Samwell
- Thank you received: 1
- gwolever
- Thank you received: 8
I called Jim at Redline Cycles in Skokie and he set me up with the Pingle valve and an adapter plate for my bike.
The install went smoothly and was very simple. The only thing I had to do really was to cut/grind a small circular hole where the slot was for my original petcock. The original petcock had a flat shaped filter, whereas the Pingle has a circular shaped filter. I didn't really need to take off much to fit it in, so it was an easy job. The instructions for this come with the adapter. I just used a stone grinder on my rotozip to make the hole more circular.
I'm very happy with it and I highly recommend it if you are converting to a new valve. Give Jim a call, he'll set you up.
1982 KZ1000 CSR
- Thank you received: 2098
If in doubt about application and/or fitment, give'em a call.
Click here > www.z1enterprises.com/ListItems.aspx?keywords=pinge
- Thank you received: 1656
With the Pingel type you have to ream out the hole 2-4mm to accept the screen. sparks + fumes = boom.
Vacuum petcock. When a vacuum petcock fails, it's usually the diaphragm. The typical rebuild parts are listed as Active at Kawasaki.com, so you should be able to get them from the dealer. Or from Z1Enterprises.com. Z1Ent probably also has a K&L rebuild kit... either the complete kit or the diaphragm kit. I prefer the vacuum type.
- jbalet666
so back off the carbs go and parked in the garage again hahaha
81 650csr
AoA
- Thank you received: 2829
- jbalet666
650ed wrote: Where are the carbs leaking? If the leak is coming from the overflow tubes you don't need to remove the carbs to address it. Ed
Its either coming from the float bowl gaskets or the fitting that attaches the fuel hose to the filter
What I think might have happened is that the The new system filled the bowls it wet the gaskets and now its leaking that or the float needle is stuck or overflow is pinched
81 650csr
AoA
- jbalet666
81 650csr
AoA
- uncle nick
- Thank you received: 5
Hope you're as lucky - My Dad used to say, 'always check the simple things first!'
1981 KZ650 CSR
- jbalet666
81 650csr
AoA
