Alternative to my BS34's.
- baldy110
Re: Alternative to my BS34's.
05 Jun 2013 13:13
I had no detonation issues with my engine combo. What compression ratio are you running, mine is 10.25-1 and I just run premium gas, timing is stock with a Dyna S ignition and coils.
- kimsmith4807
05 Jun 2013 21:17
C/R is 10.5 : 1. Detonation goes away when I have the timing 6 degrees retarded from stock. Thought my low rpm problem was related to being too retarded and set things back to factory. I know now I wasn't so I might go back. I'm excited about upgrading the carbs. Might not happen til late summer but it will happen. I documented my full frame off rebuild on another forum, (sorry), and I spared nothing, cut no corners when it came to the build. Paid top dollar for what were probably some of the last nos stuff on the planet. I've been told by others and you guys have reinforced the fact that a motor like mine deserves something better than the stock CV's. I look forward to coming here, getting to know many of you and sharing our interest for one of the greatest bikes ever built.
1981 KZ1000-K1 LTD
- LarryC
05 Jun 2013 22:08
You can try backing our intake cam off a couple of degrees to delay IVC and see how much it drops your static cylinder pressure.
Larry C.
- LarryC
06 Jun 2013 08:20
One more little bit of info for you. If you hear the knock, it's wise to pull the spark plugs and look closely for little balls of aluminum on the insulator and base ring.
Larry C.
- Powerstroke_fan
06 Jun 2013 08:35 - 06 Jun 2013 08:41
I was running rs36 for my old motor which was a 1075 10.25 to 1 with a j model head which dropped my compression one point. So i never had any detontaton issues. I had the psp 3x cams. My bike always wanted to stumble till round 3000 then it would just come right out and run!!! I was told it was the cams and lower compression. But i got used to it. As far as the carbs rattling, mine does it also. They all do, from what i understand. Anyway with my new motor, i dont have that problem. It will take right off. Yet you can still feel the "power band come in round 3000 and up. It seems like the bike pulls harder and smoother and it revs allot quicker. Now i cant really be into while shifting thru the gears it will just blow the rear tire off or stand up. i perfer it smoke the tire. I dont want to blow my new rebuilt front forks. Everytime your getting on it from any speed. It makes the front end feel so lite.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 06 Jun 2013 08:41 by Powerstroke_fan.
- kimsmith4807
06 Jun 2013 18:59
Not completely ready to give up on the cv carb. I still think I just simply have an over rich idle circuit due to the lower vacuum at low rpm. Trying to find what a stock motor would pull for vacuum at one of the carb nipples and tomorrow I'm going to hook up a gauge and see what I'm actually pulling.
1981 KZ1000-K1 LTD
- kimsmith4807
06 Jun 2013 19:49Not sure if you're pulling my leg Larry or what. Would those balls of aluminum be part of the motor coming apart? Did a plug check, just a little sooty down and around the insulator. No aluminum balls.LarryC wrote: One more little bit of info for you. If you hear the knock, it's wise to pull the spark plugs and look closely for little balls of aluminum on the insulator and base ring.
1981 KZ1000-K1 LTD
- LarryC
06 Jun 2013 20:33 - 06 Jun 2013 20:36kimsmith4807 wrote:Not sure if you're pulling my leg Larry or what. Would those balls of aluminum be part of the motor coming apart? Did a plug check, just a little sooty down and around the insulator. No aluminum balls.LarryC wrote: One more little bit of info for you. If you hear the knock, it's wise to pull the spark plugs and look closely for little balls of aluminum on the insulator and base ring.
Not pulling your leg Kim. It happens from serious detonation. Glad you're not seeing it.
The pilot circuits are easy to dial in. Count the number of turns for each screw until they are lightly seated [closed]. Start with 2 full turns out from lightly seated. Adjust from there. Generally if you need more than 4 turns out, you want to go up 1 on the pilot. Less than a turn out, you might try going down one on the pilot. In most situations, the stock pilot is plenty if you have a jet kit.
Larry C.
Last edit: 06 Jun 2013 20:36 by LarryC.
