KZ440 Single Carb Conversion
- punisher11b
Re: KZ440 Single Carb Conversion
06 Jun 2015 10:21 - 06 Jun 2015 10:22
I'm new to these carbs too. However a good diagnostic tool would be to hit the air filter with some starting fluid and see if it runs better or worse. If it does then its deffinatly a carb adjustment. If not then it may be something else. Just my 2 cents.
- good luck
Last edit: 06 Jun 2015 10:22 by punisher11b.
- Randombeat
- 0 to 100 real quick...
06 Jun 2015 10:30
Baretto, .do you happen to remember the brand ofk the bar end mirror on your bike, and/or where you got it?
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- barreto
06 Jun 2015 10:32
I'm pretty sure they were just standard, cheap bar end mirrors on amazon-
www.amazon.com/Universal-Inceased-Davids...words=bar+end+mirror
- punisher11b
12 Jun 2015 16:16
No eBay APP ID and/or Cert ID defined in Kunena configurationJust in case anyone ever needs a throttle cable, this one fits the stock throttle grip and the mikuni vm34 carb. It's a bit long but for 9$ including shipping you can't beat it.
- good luck
The following user(s) said Thank You: zayleos
- Whistle440
22 Jun 2015 00:18
just curious, i have done the same conversion, but with a K&N filter and manifold from 11th hour. i have put the exact jets in, as you listed for what worked for you, but it runs extremely rich, so i have went down to as low as a 17.5 pilot and a 140 main, still super rich. now it comes to the float i assume. mikuni said 22mm to 24mm on the tang adjustment. do you recall what yours was set at? my elevation is similar to yours btw. but this thing turns clean plugs to charcoal in a a matter of 5 mins of running, it idles decent, after a few tang adjustments, but when i throttle up, it sounds bad, smells like fuel, and bogs at about 3500 rpm... im losing my mind on this thing! do you recall what your tang is set to on yours? and regardless of what mikuni said, should i continue to add height to the tang to lean it out?? :evil:
- punisher11b
22 Jun 2015 02:43 - 22 Jun 2015 02:50
I'm going through the same exact scenario. I did find this to be helpful though.
www.amckayltd.com/vm34-36.pdf
Hope it helps.
BTW if you figure it out please post your findings.
Hope it helps.
- good luck
Last edit: 22 Jun 2015 02:50 by punisher11b.
- Whistle440
22 Jun 2015 03:33
I will certainly let you know as soon as my finding perhaps change the way this paper weight is running. I know its within the carb, before i changed the exhuast to a low restriction exhuast and a low restriction air filter, with the cv carbs its ran great of course, but either way before i press the start button, when i get off work in 20 hours of course, im going to re assure the specs on the points and do a valve adjustment, i broke the bike down to clean it up about a year ago, and it has been a on going project for about a year now, im ready to ride finally an now this fun. :sick:
- punisher11b
30 Jun 2015 13:30 - 30 Jun 2015 13:35
For anyone else who looking for info on the vm-34 carb . I live at 5000 ft in a dry climate. I'm running a single vm-34 on my 1980 kz440 Ltd. The following is my setup on the carb. I have a 11th hour industries 2 in 1 manifold. Although the manifold was extreamly lopsided because it is a left side exit (feeding the right cylinder to much gas and the left very little) I was able in install a needle valve on the rich side of the manifold and run it strait to the air filter to overcome that problem.
I'm using a #30 pilot jet, #170 main jet , needle clip at 1st position ( the tip top), air screw 3 turns out and a K&N high flow air filter to top it off (helped a bunch for getting extra air) .
Attachment not found
- good luck
Last edit: 30 Jun 2015 13:35 by punisher11b.
- CptHaddock
12 May 2016 04:42
Bringing old thread back to life to add to it. Huge thanks to the dudes who've posted on here. I just did a VM34 carb swap on my 79 kz400 using info strictly from this thread. Welded up a cheap 2-1 intake out of some 1 1/2 inch exhaust pipe. Grabbed the GY6 throttle cable suggested earlier (definitely long but bolts up fine). Put everything together and it started immediately. Idles way smoother than it ever did, got a little tuning to do still (hesistates if you open the throttle up too fast) but once it starts to pick up RPM it pulls pretty hard.
Will post pics shortly.
Joël
79 - 400 LTD
79 - 400 LTD
- zayleos
12 May 2016 07:35
Hey guys, I sold my KZ440 (still a little bummed about it) and am selling a VM34 Roundslide Carb and an 11th hour industry 2 to 1 manifold for the KZ440. Both are brand new, Carb-$75 Shipped and Manifold $85 shipped. If anyone wants em, feel free to hit me up!
- lewisdg192
01 Jun 2016 06:32
bringin old thread AGAIN back to life
anyone having warm start issues with the 11th hour manifold?
vm34 30 pilot top clip 150 main uni filter exhaust cut after mounting bolts
- daniellevesque44
05 Jun 2016 13:38 - 05 Jun 2016 13:40
zayleos
still have your carb and manifold for the kz440?
Last edit: 05 Jun 2016 13:40 by daniellevesque44.
