Megasquirt Pics
- cnyl
Re: Megasquirt Pics
01 Jul 2006 10:37
Sweet!
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- Dave Sloan
Re: Megasquirt Pics
02 Jul 2006 00:17
I have got a rough base map on the 650 now, I made up a Tech Edge 3eo WB o2 which has a display on the controller that I am using to set up the AFR ratios. It is going lean under rapid acceleration so I will need to set up the accel enrichment. I have been tuning with a palm but I managed to drop it off the bike this afternoon and the screen on it got broken . We have just bought 2 palm 3c off e bay, one with a few parts missing but the screen is still good, Laughing. I must say that hte palm is a god send as I would really struggle to get the table tuned. I am going to get a new battery for my lap top so that I can try auto tune once I am a bit more familiar with the programs etc
Cheers
Dave:blink:
Cheers
Dave:blink:
Z650B2 - Injected
- steell
Re: Megasquirt Pics
02 Jul 2006 01:05
I assume you are running Alpha N? And what Engine Temp sensor are you using and how did you mount it?
Are you using a GPz1100 fuel pump?
- Dave Sloan
Re: Megasquirt Pics
02 Jul 2006 01:09
yep, GPZ pump. Temo sensor is an NTN thermister epoxied into a wire lug that is underone of the cam box cover bolts, used easy therm to sort out the files for the ecu, worked a treat
Z650B2 - Injected
- Dave Sloan
Re: Megasquirt Pics
06 Jul 2006 23:14
HI guys,
I have been playing around with the ms map, its awesome to be able to change the bies mixture with a push of a button, had a bit of a mishap with the palm, it fell out of the holder at around 110kph iconshocked3 and although it wasnt ridden over it got damages and had a broken screen but I was lucky enough to be able to find a one that a screen that was ok
Palm tune works well and I get an instant response on the WB display, only done 1/2 the map and have the AFRs in the low 12s
but I want to gat h e afrs to around 12.5 to 13.5. Once ai am happy with the map I will use the auto tune program and see how much of a difference there is between the 2 maps
Z650B2 - Injected
- apeman
Re: Megasquirt Pics
07 Jul 2006 11:31
I love mixing old and new technologies. If you ever have the time, you should write a full article on your system, and post it up for all of us to read, and envy.
Great job!
Great job!
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- pumps
Re: Megasquirt Pics
07 Jul 2006 15:41
Yes I am fascinated and in awe.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- Dave Sloan
Re: Megasquirt Pics
11 Jul 2006 00:44
Ill see what I can do re the write up as soon s I get the bike tuned, went for a ride down the coast on Sat 250 km, bike ran well afrs around 12.5 to 13.5, need to work on the higher rpm bins but speeding is a problem:unsure: also need o find a quite longish road with little or no traffic. Dont know where all tehse cars come from these days
Z650B2 - Injected
- IowaKZ
- '80 G1 Classic
Re: Megasquirt Pics
11 Jul 2006 18:47
Dave, just sent you a pm. Thanks
1980 G1 Classic
Bettendorf, Iowa
Bettendorf, Iowa
- Dave Sloan
Re: Megasquirt Pics
10 May 2007 02:52
Ok, 650 is now running ignition on the megasquirt ecu after the '81 gpz750 ignition icignitor blew up on the way to the april fools run (400km from home)
With teh help of my mate Ian we have modified the megasquirt ecu to do the ignition as well. Had problems with elct noise interfiering with the sensor inputs to the ecu and causing resets, changed the plug leads to spiral wound ones and fitted resistor plugs (NGK BR8ES)
and shes all good. I have used one of the std kawasaki vr sensors and have a chain sprocket taht I machined the diameter down removed a tooth (12-1 toothed wheel for $3.80)
Z650B2 - Injected
- donthekawguy
Re: Megasquirt Pics
10 May 2007 05:12
I don't know what the hell your taking about but it seems cool.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- BSKZ650
Re: Megasquirt Pics
10 May 2007 05:42
That is way cool, I have thought about putting a system on my bike, you stepped up to the plate and did it;)
what are you using for a air flow sensor and air temp sensor?
does anyone have a dyno that you could run the bike on and tune it that way?
77 ltd1000, current rider
76 kz900, just waiting
