New to the forum, 1981 KZ440 LTD starting problems
- Milpool
Re: New to the forum, 1981 KZ440 LTD starting problems
04 Apr 2013 01:58Nebr_Rex wrote: Pull carbs and completely clean them. And get some new carb boots. You will need an impact driver or needle nose visegrips to remove the screws.
The screw head on the bottom of your pic is your idle mixture screw.
Looks like it has not been touched.
They don't seem to be pulling in air, but I was considering replacing them anyways, $21 a piece on partzilla though, ouch. That picture is from the first time I took them apart, before I touched the screws. They were both set to 3 and 1/4 turns (backed off of snug). I tried turning them in and starting the bike a couple of time until I got to 1 and 1/4 (backed off of snug), but it didn't help with the high idle.
- jesiman
04 Apr 2013 10:54
Where are you finding the hoses for the carb? The ones I see on there are all obsolete.
79 KZ650 SR
84 ZN700 donor
81 KZ440......no title....
84 ZN700 donor
04 Apr 2013 11:42Nebr_Rex wrote: Pull carbs and completely clean them. And get some new carb boots. You will need an impact driver or needle nose visegrips to remove the screws.
If you soak the carb holder screws with Kroil for a couple days and use a JIS screwdriver tip (or a modified Phillips) they will come out easily and will not be damaged. Ed
The following user(s) said Thank You: Milpool
- Milpool
04 Apr 2013 13:00650ed wrote:Nebr_Rex wrote: Pull carbs and completely clean them. And get some new carb boots. You will need an impact driver or needle nose visegrips to remove the screws.
I've got some deep creep and a cordless electric impact, so those screws don't scare me. I'm just pretty sure that there's no air leaking in through there. Tested three times, once with carb cleaner and twice with propane, couldn't find a leak. Worth replacing anyways?
04 Apr 2013 15:00
Depending on how you tested the carb holders, you may want to give it one more try. When testing them, be sure to temporarily set the idle as low as possible without killing the engine. The lower the idle the better. This is because at very low idle not much air can pass through the slides and this creates higher vacuum within the carb holders. Spray carb cleaner around the mating surfaces between the carb holders and cylinder head. If they are leaky, this idle will drop and very likely stop the engine. That's what happened on mine when I needed to replace the holders.
Be sure to take a look at the following link regarding the cross head screws on the bike (and not just the ones on the carb holders). They are not Phillips. Ed
kzrider.com/forum/21-tools/532335-budget...ewdriver-tips#532335
- Nebr_Rex
04 Apr 2013 23:50
Pull your carbs,remove float bowls and take a few pics.
Then check to make sure your pilot and main jets are the right size.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Milpool
16 Apr 2013 21:49Nebr_Rex wrote: Pull your carbs,remove float bowls and take a few pics.
Sorry it's taken so long to reply, I don't get too much time to wrench on the bike these days. So I popped them off and took a few pics, not sure of how to check the jet size, but I called the PO and he said he never changed them...
A little bit of crud in there, cleaned it out and re-installed the carbs, exact same issue. Any ideas?
- Nebr_Rex
17 Apr 2013 00:10
I was concerned that the little orange plug next to the two main jets had fallen out.
Your pilot jet is underneath that plug.
You need some screwdrivers that fit the slots in the jets precisely.
Also apply a little downward pressure to avoid burgering them up.
Then clean all passages
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- rooftoplounge
25 Aug 2013 03:03
Hey guys,
Where do you get those little rubber plugs? The ones that were in my 76 carbs were totally shrunk and I've been looking all over for what to replace them with. I picked up a couple of kits from Z1 but the rubber plugs were not included... Thanks!
- JR
25 Aug 2013 12:33
Those plugs should have an O-ring on them to keep them snug fit. Was there suitable size o rings in the kits you got from Z1 ?
