Synching carbs with a 4 way homemade manometer?
  • ironslave
  • ironslave's Avatar Topic Author
  • sup
Re: Synching carbs with a 4 way homemade manometer?
12 Feb 2013 03:42 - 12 Feb 2013 03:46
#572047
This whole system is so ghetto... I try not to question it... The theory is sound. so let's rock it. I just have to manage to figure out how the adjustment screws work without breaking anything.
1981 KZ750 LTD
Last edit: 12 Feb 2013 03:46 by ironslave.
12 Feb 2013 11:05
#572073
If the lock nuts are frozen soak them for a couple days with Kroil or another high quality penetrating oil so you don't break anything by forcing it. They should loosen with very little effort. Ed
  • donthaveakawman
  • donthaveakawman's Avatar
12 Feb 2013 11:09
#572076
I used spray gasket sealer on my carbs holders a long time ago, I'm still trying to peel it off those screws.
  • ironslave
  • sup
12 Feb 2013 19:45
#572139
Ok got my carbs synced and adjusted my idle and pilot valves and now it runs like a champ.
I used 2 stroke oil for the fluid. Having all 4 together was messy and inaccurate so I did 2 carbs at a time. I synced 2-3 then 3-4 and then 1-2. It runs like a different animal now. Idle is much more stable and it is easier to start. Smooth through the entire range. For a home made sync tool it worked fantastically.
1981 KZ750 LTD
  • donthaveakawman
12 Feb 2013 21:06
#572145
you may see a huge difference while riding, I got my mixture screws to where it lurches through gears, ouch my neck ouch my back.
  • ironslave
  • sup
12 Feb 2013 23:00
#572168
I took it for a 30 minute cruise around town and no problems whatsoever. All I am waiting on now is for my throttle cable to arrive.
1981 KZ750 LTD
  • martin_csr
  • martin_csr's Avatar
13 Feb 2013 12:36
#572237
ironslave wrote: Ok got my carbs synced and adjusted my idle and pilot valves and now it runs like a champ.
I think w CV carburetors, one method is to sync them in pairs: 1-2, then 3-4, then sync 1/2 & 3/4 as a pair.
  • donthaveakawman
15 Mar 2013 22:50 - 15 Mar 2013 22:52
#577129
maybe I'll try that 1.,2 2,3 3,4 needs to be done again pre-valve shim job was not a good id.
other methods are acceptable I found this on youtube
:woohoo:
Last edit: 15 Mar 2013 22:52 by donthaveakawman.
  • Britbiker
  • Britbiker's Avatar
17 Mar 2013 00:31
#577308
I made a similar one for my twin Honda it works just fine Mine used 36inch ruler and the plastic pipe just taped with clear scotch tape. cost $5
If I make an identical one I could use it for my Kawi four,good luck yours is worth keeping and working on, sorry at this stage I cannot give much advice on setting up a Four ,
Keith
