Engine racing at idle
- Motor Head
Re: Engine racing at idle
25 Oct 2012 22:28 - 25 Oct 2012 22:39
Have you checked the small seals on each side of the throttle shaft? They can be a vacuum leak. Seals are available, at least for the BS34, I would think the BS38 would be too or possibly the same seal.
Yes they are the same, look here Topper:
www.mikesxs.net/product/48-5021.html
Last edit: 25 Oct 2012 22:39 by Motor Head.
- donthaveakawman
25 Oct 2012 22:57
not trying to point out the obvious as though no-one could see it. maybe it is the throttle cable can be adjusted, is there any play in it.
80 kz750h drilled airbox/w k&n, stage 3 dynojet, 4 to 1 muffla, ebc brake pads
- Topper
25 Oct 2012 23:55donthaveakawman wrote: not trying to point out the obvious as though no-one could see it. maybe it is the throttle cable can be adjusted, is there any play in it.
No, it's not the cables. It's not so bad that I can't live with it, would just like to get it right.
I'm thinking it's likely that right carb holder or the balance tube between the carb holders not fully sealed.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- donthaveakawman
26 Oct 2012 00:36
i had some problems with mine, this forum has helped me a-lot. as i was taking the intersection of xxxxxxx xxxxxx road and xxxxx ave i decided haul ass to make the light. i had to lean really good on this one and i got so low that i saw the camry in the turn lane was missing a lug nut, also i caught my boot under my footpeg.
- donthaveakawman
26 Oct 2012 01:55
had to find this photo.
Attachment 381851_354401491252708_1309513149_n.jpg not found
