Cracked my pump cover assembly.
15 Oct 2012 20:19 #554054 by DocWrath
Cracked my pump cover assembly. was created by DocWrath
Was putting my carb back together and I cracked the cover assy, pump (part number 14025-1139). I have been looking for it every where with no luck. So far my only options are buy a whole new carb with the part on it for around $100 or maybe something like J-B Weld. Does anyone have any experience with that stuff? Do you think it would work on this part? Plz help this is absolutely devastating for me. Tell me I'm not SOL
P.S. saw an old post for same problem and he found the part at adamsvintagemotorcycles.com but I tried there and they dont have it in stock.
79 Kz650
I fix people not bikes!
  • lushbaugh
  • everybodys a pro......
15 Oct 2012 20:55 #554063 by lushbaugh
Replied by lushbaugh on topic Cracked my pump cover assembly.
show a pic ill rummage my stuff. what carbs?
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
15 Oct 2012 21:47 #554079 by DocWrath
Replied by DocWrath on topic Cracked my pump cover assembly.
its dark but i hope this is good enough if need be I can pull it off tomorrow for better pics. Not sure what carb it is. Its on my 79 kz650 if that helps.
Attachment IMG_5492.jpg not found
Attachment IMG_5493.jpg not found
Attachment IMG_5491.jpg not found
other side
Attachment IMG_5494.jpg not found
Attachment IMG_5496.jpg not found
I can pull up photoshop too if I need to highlight the crack. Thanks!
79 Kz650
  • lushbaugh
15 Oct 2012 21:50 #554080 by lushbaugh
ill get back to you when i go to my old work and get it. pretty sure i got one.
The following user(s) said Thank You: DocWrath
15 Oct 2012 21:56 #554082 by DocWrath
Awesome man thank you so much!
79 Kz650
19 Oct 2012 21:19 #554766 by DocWrath
I'm still dead in the water here. Does anyone know where I could get this part? Any help at all would be greatly appreciated.
79 Kz650
19 Oct 2012 21:43 #554768 by Patton
Replied by Patton on topic Cracked my pump cover assembly.
DocWrath wrote: I'm still dead in the water here. Does anyone know where I could get this part? Any help at all would be greatly appreciated.
Another option could be to do away with the accelerator pump feature.
Here are some threads that might be of interest in that regard.
www.kzrider.com/forum/3-carburetor/39218...t=20&start=20#392927
www.kzrider.com/forum/3-carburetor/38541...le-at-6500rpm#388011
www.kzrider.com/forum/3-carburetor/21055...-missing-part#210767
www.kzrider.com/forum/3-carburetor/13864...pumps-missing#138642
www.kzrider.com/forum/3-carburetor/12839...b-rebuild-kit#128743
Good Fortune! :)
19 Oct 2012 22:13 #554775 by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic Cracked my pump cover assembly.
I'm just going to leave this right here:
www.oldkawman.com/
19 Oct 2012 22:26 #554776 by DiamondSkyBlue1000
23 Oct 2012 21:12 #555455 by DocWrath
I really appreciate the help guys but I think lushbaugh has a part for me! If something else happens though its good to know that I will have a back up plan.
79 Kz650
  • mark1122
  • Keep twisting it
23 Oct 2012 22:28 #555475 by mark1122
Replied by mark1122 on topic Cracked my pump cover assembly.
i have used JB weld inside a float boal. it does not hold up to gas for more than a season or 2.
i have had carb parts welded, but u need to find a guy that can do fine welding. these kind of guys work on molds for plastic injection molding factories.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
28 Oct 2012 10:52 #556100 by DocWrath
Thanks for the input on the JB-Weld mark. That is something i definitely don't want to figure out on my own.
It looks like Lushbaugh couldn't find that part for me so I will have to get rid of the accelerator pump assembly. I'm going to be gone for the next 2 weeks doing a field training exercise so I wont be able to start that until then. I also ordered the dynojet stage 3 jet kit. So I got a lot of work ahead of me. I just cant wait to ride again!
79 Kz650
