29 smoothies with a crazy leak!
- old_skool_77
- Woot Woot
03 Oct 2012 16:38 #552246
by old_skool_77
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
29 smoothies with a crazy leak! was created by old_skool_77
I got a set of 29 smooth bore mik's. clean as can be. Problem is when I installed them, they pour gas out of the one and two carbs like niagra falls. Anyone know why this happend? Three and four was without leakage. Any body tell what this caused by and maybe tell what to do to get em fixed. Thanks to all and any help.
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- Del_Herring
- Thank you received: 29
03 Oct 2012 16:44 #552248
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic 29 smoothies with a crazy leak!
Sounds like float valves aren't closing. Since you say they're clean, the next thing I'd consider, is that sometimes old floats can get cracks, and fill up with gas, thus not floating. I'm not sure what they floats are made of on those carbs, but it would be a decent thing to check. Might also check how they're adjusted to make sure they can float all the way to where the float valves seals, and aren't bent or something funny to where they can't go up.
- 4TheKZ1000
- Visitor
03 Oct 2012 16:46 - 03 Oct 2012 16:59 #552249
by 4TheKZ1000
Replied by 4TheKZ1000 on topic 29 smoothies with a crazy leak!
were they worked on? do you know the history of the carbs?
Last edit: 03 Oct 2012 16:59 by 4TheKZ1000.
- old_skool_77
- Woot Woot
03 Oct 2012 17:49 #552255
by old_skool_77
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
Replied by old_skool_77 on topic 29 smoothies with a crazy leak!
Right on. I checked the floats and found them to be in good condition. They are made out of maybe some type of copper or brass. And they are sweated together with some kinda a solder. Not sure what. But I held them in a bowl of gasoline and looked for air bubble and turned up no leaks. All are identical on all four floats as far as tabs being in the same position. As far as being worked on, I haven't the slightest clue. Needle valves are smooth around the point. Seats look ok as well. Fuel comes right out the intake side of the carbs as soon as I turn the petcock on. Hmmm, am I over lookin another possibility? Carbs look really clean inside and out. Gaskets look new and mains and pilot jets look brand new so I don't know if that's all that had been done to them before or if they have been rebuilt before. I bought em from a flea market for 25$. Got em for a steal regardless but would like to run them on my 1000ltd. Thanks.
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- kzz1king
- Thank you received: 52
03 Oct 2012 17:53 #552256
by kzz1king
Home built KZ1000 turbo setup
Replied by kzz1king on topic 29 smoothies with a crazy leak!
Make a rack and a temp fuel tank with a way to shut off fuel.. Drop the bowls and hold the floats up. I have had 2 floats go bad on mine,thing is they looked good. Polished them but it didnt help.
Wayne
Wayne
- old_skool_77
- Woot Woot
03 Oct 2012 17:57 #552257
by old_skool_77
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
Ok I'll check into that. Can't really see what goin on with floats while bowls are on. Lol. Thanks
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- Thank you received: 797
03 Oct 2012 18:19 #552262
by 531blackbanshee
Replied by 531blackbanshee on topic 29 smoothies with a crazy leak!
sonufa $25.00 dollar smoothbores :woohoo: !!!!!!!!!!!!!!!!!!!!!!!!
geewheellickerswally you gottem too cheap,so know you are going to have make up the discount in time spent fiddling with them :laugh: .
gotta be floats or needle and seat.
- old_skool_77
- Woot Woot
03 Oct 2012 19:08 #552268
by old_skool_77
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
Right! I bout came outta my skin when ol boy told me twenty five duckies! I had 200 thinkin I could get em for a steal at that price! But yeah, I have a feelin they are gonna mess with me mentally for a little while trying to get em figured out. Hopefully not too much. Ill crackem open again to see what my floats do with out the bowls and a bleeder tank of fuel flowin thru the needles. Thanks
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- 4TheKZ1000
- Visitor
03 Oct 2012 19:32 #552275
by 4TheKZ1000
ya got what ya paid 4..... :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
- zukdave
- Thank you received: 229
03 Oct 2012 21:23 #552299
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic 29 smoothies with a crazy leak!
I paid $140.00 for my 29's then spent another $200.00 or so
on needle's, seat's, gasket's and a big hand full of jet's.
There's no kit's for the VM29's you have to get stuff piece by piece X4.
Call Robert at Z1 he hooked me up with all my need's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- old_skool_77
- Woot Woot
03 Oct 2012 22:02 #552305
by old_skool_77
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
Yeah I didn't think I was gonna get off that easy with payin what I did. Robert is a kool kat. We've talk carb junk a handful of times. I've prolly got some needles in my junk box. Just gonna have to dig around.
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- 4TheKZ1000
- Visitor
03 Oct 2012 22:14 #552307
by 4TheKZ1000
look, this is not a cookie cutter issue....you need to go though these carbs with a fine tooth comb. There are several different things that could be wrong with each carb....just my view on it.
