- Thank you received: 23
VM26SS main jet sizing in thousands of an inch?
- 74ullc
My '77Kz1000ltd has 115 mains and I believe they are lean for the bike. I am running stock exhaust and pods. (wish I had the original airbox setup, think I might have found one!)
I have gone thru the other stuff, valves, timing, vacuum leaks, repowered coils with relay and everything helped but I still have a coughing, sputtering at WOT. I moved the needle clip down one position and that helped ALOT, it moved the bad spot from 1/2 throttle and up to about 3/4 and up.
So at this moment I have the carbs off and am thinking of drilling out the main jets but dont know how far to go. The way I figure it, if it gets better after drilling I know I am too lean, gets worse than I was too rich. Either way the mains are wrong so no loss to me.
I can get a #58 - (.0420) drill thru the #115 main now. Just wondering if I should step it up 2-3 or more like 5-6 thousands. I have no idea how much difference there is between the sizes. Anyone know about what a 120 main would be?
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- Nebr_Rex
- Thank you received: 300
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- 74ullc
Nebr_Rex wrote: And how much do main jets cost?
Like I said, this is to confirm that I have a lean main jet. If I drill out the bore and it runs better than I know that 115 mains are too lean. From there I can order some larger size mains and get it right. Cost has nothing to do with it.
What I dont know is how much of a size difference there is between the different mains. If I knew the bore size of any other main I could figure that out. If the sizes increase evenly that is. I would like to know how much to drill to get to around a 120-125 main. I'm thinking about .005 larger from my .042 (115) size now but not sure.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- gd4now
- Denco where did you go?
- Thank you received: 445
You can run a simple test to see if you are lean rich. When the issue happens put the choke on partway and see if the issue gets better or worse. If it gets better you are lean, if it gets worse you are rich.
AS to sizes of jets, IIRC it is as follows
115 jet = 1.15mm or 0.045275 of an inch
117.5 jet = 1.175mm or 0.046259 of an inch
120 jet = 1.20mm or 0.047244 of an inch
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- 74ullc
Yes, your info on stock carb setup are correct. When I bought the bike in March the engine was all stock except he had put pods on it and changed the jets to a 115 main and a 17.5 pilot. Bike still has the stock exhaust.
At first I thought maybe he had overjetted the bike, didnt think just pods would make that much of a change. But based on what I have ready here and the way it runs I was lean. So I moved the clips down one slot and that made a HUGE difference in how it runs. It used to be really touchy to opening the throttle, had to roll into it very very slow or it would start lurching and caughing. After moving the clip down I can get into it more than before and it pulls much harder but it still has the issue at WOT.
I have tried the choke trick and it seems to help maybe. Hard to tell because any change is very small. Plus running WOT in 5th gear the bike is moving and I'm focused on driving the thing.
What I can do is be going about 40-50 in 5th gear and quickly roll the throttle to WOT and the bike will start lurching and loose speed and never recover. A friend of mine with a 78 KZ650 will not do that. His will lurch and then recover and accelerate.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- kaw-a-holic
- Thank you received: 249
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- 74ullc
kaw-a-holic wrote: Main jets are to small. Would you like an airbox? Would only cost you S&H. I have some of the clamps. All the rubber is pretty good except oneis ripped. I use a Henry Abe air filter. It works much better than the pods. Mine is off my '77 KZ 1000
Sounds like lean main jets to you? What is a Henry Abe air filter? Have to do some checking on that.
Yes I would like a stock airbox!!! I would rather just go with the stock setup instead of messing around with jetting changes. I'm not trying to set any speed records, just want a bike I can enjoy so the stock setup is fine for me.
The guy I bought the bike from has some of the airbox parts but not everything. He is missing the flange parts that hold the tubes to the box. Looks like three parts, two gaskets and one large flange? Just guessing from seeing the drawing on bikebandit. Also missing the clamps, and the tubes are ripped.
Is the airbox setup the same on a LTD and non-LTD? If so I will take what you have. I'll message you.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- 74ullc
Tomorrow I will have to go for a longer ride and see how it does. Then looks like I will be buying some 125-130 mains.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- Thank you received: 2098
During mid-range throttle positions, fuel mixture is governed by the jet needle, needle jet, and slide position (unaffected by a larger than stock main jet size).
For example, if the fuel mixture at half throttle is too lean with the stock main jet, a larger main jet would not be expected to enrichen the mixture at half throttle.
For another example, if the fuel mixture at half throttle is too rich, a smaller main jet usually won't produce a leaner mixture at half throttle.
The most common method of adjusting the mixture during mid-throttle range is by changing the clip position on the jet needle. Whereby a relatively lower clip position enriches the mixture by raising the jet needle's position inside the needle jet.
The carb's pilot circuit governs fuel mixture at idle and continues influencing the mixture until about 1/4 throttle position where the mixture then becomes governed solely by the jet needle, needle jet, and slide position.
- 74ullc
I took the bike for a longer ride today to see how the new main jet size (127) did. WOW!!! Bike pulls much harder! This is my first bike and when I got it it was not running very well at all. So I had no idea how the bike should have been running or how fast it really is. The sound that I am getting out of it now is also amazing. Might just be crazy but to me it sounds like a 308GTS.
It still has a little more lurch than I like when rolling very quickly to WOT from a steady cruise speed in 5th. The bike will now recover and accelerate from doing that, with 115 mains it would never recover, so I am for sure on the right track. So I will try a bit larger mains. At 127 now thinking about trying 130-132ish. I would rather go too rich and then have to work back to be sure I am giving it all the fuel it needs.
Never would have figured that it would need so much fuel for pods over the stock airbox setup. I am at sea level so that helps too.
I have to recommend for anyone with a stock setup to repower their coils with a relay. I have done it on my bike and a friends '78 kz650. On both bikes it made a HUGE difference in how they run. So much better now, more power, smoother idle, easier starts, barely have to choke 'em on startup, etc. Well worth the effort!
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- kawasaki mike
- kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
- 74ullc
I moved the clip down one position to raise the needle not lower it. The bike was running lean in all throttle positions when I got it.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
