Bad o-rings on pilot-screws
04 Jul 2012 21:25 #533892 by Bunty27
Bad o-rings on pilot-screws was created by Bunty27
Two of the o-rings for the pilot screws on my TK-22 carbs(kz550-c3 '82) are bad. Is there a way to buy just the o-rings from someplace? I can buy the pilot screws with the springs and o-ring's but I'm unable to fine them anywhere? Any suggestions?
1982 KZ550 LTD
04 Jul 2012 21:30 #533893 by MFolks
Replied by MFolks on topic Bad o-rings on pilot-screws
Maybe a plumbing supply store that has "Viton O-rings", or here:
www.allorings.com/
O Rings
www.cycleorings.com/
The following user(s) said Thank You: BlackZ1R, Bunty27
04 Jul 2012 22:30 #533905 by Bunty27
Replied by Bunty27 on topic Bad o-rings on pilot-screws
I would've never figured this out. Thank you soo much!!
1982 KZ550 LTD
05 Jul 2012 01:05 #533932 by Bunty27
Any idea where I'd be able to find some pilot screws? The head on one of the screws is worn out and it was a bit painful to get it out of the carb. Thanks much.
1982 KZ550 LTD
05 Jul 2012 01:09 #533935 by MFolks
05 Jul 2012 01:20 #533938 by rcook52459
Replied by rcook52459 on topic Bad o-rings on pilot-screws
try bikebandit.com
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
The following user(s) said Thank You: Bunty27
05 Jul 2012 01:29 #533939 by Bunty27
Thanks much for the links. I didn't find any at z1enterprises.com
1982 KZ550 LTD
05 Jul 2012 01:44 #533940 by Bunty27
Found them on bikebandit.com. Thanks much! :)
1982 KZ550 LTD
05 Jul 2012 10:13 - 22 Jan 2013 20:27 #533981 by martin_csr
Last edit: 22 Jan 2013 20:27 by martin_csr.
  • Motor Head
05 Jul 2012 10:13 - 05 Jul 2012 10:36 #533982 by Motor Head
Replied by Motor Head on topic Bad o-rings on pilot-screws
This pack At Harbor Freight has some that fit. Put a small amount of lube on the new o-ring, so it doesn't shear/ tear when installed. Sil-glide is a good product, but just some Petroleum Jelly/ Vaseline, works great for this.
www.harborfreight.com/225-piece-metric-n...ssortment-67609.html
Last edit: 05 Jul 2012 10:36 by Motor Head.
05 Jul 2012 10:27 #533985 by Kidkawie
Replied by Kidkawie on topic Bad o-rings on pilot-screws
Sudco sells all that stuff.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
05 Jul 2012 12:37 #534007 by Patton
Replied by Patton on topic Bad o-rings on pilot-screws
